I installed a fresh copy of Ubuntu 24.04 and am unable to get the Wifi driver to work. It worked once (in recovery mode) and I don't seem to be able to do that anymore.
Here is the output of lspci -knn | grep -iA3 net
24:00.0 Ethernet controller [0200]: Intel Corporation Ethernet Controller X550 [8086:1563] (rev 01)
Subsystem: ASUSTeK Computer Inc. Ethernet Controller X550 [1043:8712]
Kernel driver in use: ixgbe
Kernel modules: ixgbe
24:00.1 Ethernet controller [0200]: Intel Corporation Ethernet Controller X550 [8086:1563] (rev 01)
25:00.0 Network controller [0280]: Intel Corporation Wi-Fi 6E(802.11ax) AX210/AX1675* 2x2 [Typhoon Peak] [8086:2725] (rev 1a)
Subsystem: Intel Corporation Wi-Fi 6 AX210 160MHz [8086:0024]
Kernel modules: iwlwifi
26:00.0 SATA controller [0106]: ASMedia Technology Inc. ASM1061/ASM1062 Serial ATA Controller [1b21:0612] (rev 02)
The output of sudo dmesg |grep iwlwifi is
[ 13.122574] iwlwifi_compat: loading out-of-tree module taints kernel.
[ 13.124393] Loading modules backported from iwlwifi
[ 13.124395] iwlwifi-stack-public:master:11510:0106cce5
[ 13.200648] iwlwifi 0000:25:00.0: pcim_iomap_regions_request_all failed
[ 13.200659] iwlwifi: probe of 0000:25:00.0 failed with error -22
I uninstalled and reinstalled linux-modules-iwlwifi-generic and don't see any change.
I have disabled Resizable bar in the BIOS settings, installed linux-generic and am currently out of ideas. I still get the "No Wifi Adapter Found"
