I'm trying to get the installed version of systemd in the following command, but it returns all lines contain the keyword "systemd".
# dpkg -l | grep " systemd "
ii gnome-logs 42.0-1 amd64 viewer for the systemd journal
ii libsystemd0:amd64 249.11-0ubuntu3.12 amd64 systemd utility library
ii systemd 249.11-0ubuntu3.12 amd64 system and service manager
ii systemd-container 249.11-0ubuntu3.12 amd64 systemd container/nspawn tools
How to make it return only the following line:
# dpkg -l | grep "__the_rule_for_systemd_"
And then, I can use awk to get the version:
# dpkg -l | grep "__the_rule_for_systemd_" | awk '{print $3}'
Here is the expected output:
249.11-0ubuntu3.12
How to write the "__the_rule_for_systemd_" for grep or is there any other command can get the installed version of systemd?
Note:
# package_name="systemd"
# dpkg -l | grep " $package_name "
The "__the_rule_for_systemd_" should also work on other packages, it should be able to get any package by that rule, not just only for "systemd".
