I installed Ubuntu 24.04 on a new Thinkpad E14 and I am unable to get the display brightness control working. I tried almost all suggestions that were proposed here: Ubuntu 20.04 brightness adjust not working
This includes all possible permutations of the grub CMDLINE. The behavior I get is the following:
With any grub CMDLINE that includes
acpi_backlight=native, oracpi_backlight=noneI get no backlight device.With
acpi_backlight=vendorI get a backlight device from the thinkpad_acpi driver, but when I change the brightness I get an IO error:
_
root@ks-laptop:/sys/devices/virtual/backlight/thinkpad_screen# cat brightness
10
root@ks-laptop:/sys/devices/virtual/backlight/thinkpad_screen# cat max_brightness
15
root@ks-laptop:/sys/devices/virtual/backlight/thinkpad_screen# echo 7 > brightness
bash: echo: write error: Input/output error
No errors are logged in the kernel. The thinkpad_acpi driver seems to be loaded correctly. These are the logs:
[ 73.218186] thinkpad_acpi: ThinkPad ACPI Extras v0.26
[ 73.218192] thinkpad_acpi: http://ibm-acpi.sf.net/
[ 73.218193] thinkpad_acpi: ThinkPad BIOS R2CET34W(1.16 ), EC R2CHT34W
[ 73.218196] thinkpad_acpi: Lenovo ThinkPad E14 Gen 5, model 21JRCTO1WW
[ 73.226016] thinkpad_acpi: radio switch found; radios are enabled
[ 73.257197] thinkpad_acpi: rfkill switch tpacpi_bluetooth_sw: radio is unblocked
[ 73.322034] thinkpad_acpi: ACPI native brightness control enabled
[ 73.396744] thinkpad_acpi: secondary fan control detected & enabled
[ 73.416288] thinkpad_acpi: battery 1 registered (start 95, stop 100, behaviours: 0x7)
[ 73.459881] input: ThinkPad Extra Buttons as /devices/platform/thinkpad_acpi/input/input17
When I enable the debugging logs of the thinkpad_acpi driver, it logs the request to change the brightness, but it doesn't log why it fails.
- With
acpi_backlight=videoI get a backlight device where I can write brightness values, but they have no effect.
I am really running out of ideas. One suggestion that I've read was to install the closed-source AMD GPU drivers, but as there are no working drivers from AMD yet for 24.04 I cannot test this.
I am running out of ideas here. Any help is greatly appreciated.
Update 2024-05-05
I have been debugging this issue further. I booted an Ubuntu 22.04 where the backlight works out of the box. The driver in /sys/backlight references the i2c-9 bus. In total this version detects 12 i2c buses. On Ubuntu 24.04, however, there are only 5 i2c buses and no i2c-9. I haven't made progress yet on why this bus isn't detected.
