My provider forces a re-connect all 24h, which breaks my XChat session. Though the connection usually is re-established within seconds, due to the changed IP the "old session" is invalidated. XChat automatically joins the network(s), but then my nick gets refused as it "is already in use". I can manually solve that by "/nickserv ghost MyUser MyPass" -- but I could not find any place to configure XChat to do that automatically. Is that possible, and if so, how?
Izzy
  • 3,620
This is based off my SU answer to a similar question
Assuming all versions work the same, you can put /msg nickserv ghost name password as a connect command under server settings for freenode.
To change your nick as well is a little tricky - type in
/msg nickserv ghost username password
Then CTRL SHIFT u a
/nick username
As one line. This should do both commands one after another.
Here is a plugin to handle automatic ghosting and identification. Just put the *.py file in your xchat scripts folder ~/.xchat2/
https://github.com/Sepero/xchat_auto_ghost
Rucent88
  • 2,058
