EDIT: Ubuntu bug posted here
some time ago I wrote a detailed answer to fix an error for lowering MTU size for a cisco compatible VPN.
After upgrading to Ubuntu 24.04 LTS, I'm unable with the same steps to lower the MTU size.
In particular, if I run the following command from the terminal
sudo ifconfig your_tunnel_name mtu 1370 up
it seems to lower the MTU size.
However, the script under /etc/network/if-up.d is not automatically triggered.
Does something change with the newer Ubuntu version?
I managed to workaround it with NetworkManager-dispatcher. The doc can be found on arch.
The scripts must be moved from /etc/network/if-{up,down}.d/ to /etc/NetworkManager/dispatcher.d/. You can use the second argument $2 to branch on the specific event (up, down...).
Also, the usage of IFACE env var must be replaced with either VPN_IP_IFACE, DEVICE_IP_IFACE, or DEVICE_IFACE as applicable.
Note: Although networkd-dispatcher is a recommended modern way to trigger scripts, those were not executed on my Ubuntu 24.04 (desktop).
Eric M.
  • 121
