My WD G-Drive connects to Ubuntu 22.04 LTS but receives the error Error Mounting /dev/sda2 at /media/ on Ubuntu 24.04 LTS. G-Drive is connected to same port regardless of Distro but 22.04 is running on a separate external NVME whereas 24.04 is running on a partition with Dual boot Internal with W11.
stumblebee
  • 4,379
This is a known bug on Ubuntu 24.04.
No solution so far: https://bugs.launchpad.net/ubuntu/+source/ntfs-3g/+bug/2062972
thiago
  • 111
Had the same issue - my /dev/sda2 was not mounting and this worked for me: https://linovox.com/how-to-fix-failed-to-mount-wrong-fs-type-bad-option-bad-superblock-on-linux/
First create your mounting point (for me this is in /media/user directory) and then mount the partition:
sudo mkdir DATA
sudo mount -t ntfs-3g /dev/sda2 /media/user/DATA/
Monika
  • 31
