I am trying to add the 45Drives repos to my Raspberry Pi Ubuntu install so I can use their Cockpit extensions. When I try to run the command, I get this error saying that curl can't write its downloaded files.
jaherron@littlebit-pi5:~$ sudo curl -sSL https://repo.45drives.com/setup | sudo bash
[sudo] password for jaherron:
Detected Debian-based distribution. Continuing...
There were no existing 45Drives repos found. Setting up the new repo...
Updating ca-certificates to ensure certificate validity...
Get:1 https://packages.microsoft.com/repos/code stable InRelease [3590 B]
Hit:2 http://ports.ubuntu.com/ubuntu-ports noble InRelease
Get:3 http://ports.ubuntu.com/ubuntu-ports noble-updates InRelease [89.7 kB]
Hit:4 http://ports.ubuntu.com/ubuntu-ports noble-backports InRelease
Hit:5 http://ports.ubuntu.com/ubuntu-ports noble-security InRelease
Fetched 93.3 kB in 1s (82.4 kB/s)
Reading package lists... Done
Building dependency tree... Done
All packages are up to date.
ca-certificates is already the newest version (20240203).
The following packages were automatically installed and are no longer required:
gcc-14-cross-base libc6-amd64-cross libgcc-s1-amd64-cross libstdc++6-amd64-cross
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
curl: (23) Failure writing output to destination
Failed to download the new repo file. Please review the above error and try again.
