31
I installed Ubuntu 24.04 LTS, and tried to install Docker Desktop following the instructions from the official site, but in the end, the first docker command can not be used if you did not use it with sudo, and Docker Desktop is not starting at all.
5 Answers5
54
$ sudo sysctl -w kernel.apparmor_restrict_unprivileged_userns=0
$ systemctl --user restart docker-desktop
for a temporary workaround.
The issue is caused by a change introduced in Ubuntu 24.04
See the corresponding Docker Desktop bug report.
23
Create a default_allow AppArmor profile
According to Ubuntu Blog it is possible to create an AppArmor profile file to create a default_allow profile mode for an application.
While this effectively allows the application to remain unconfined, it also adds a new “userns,” rule to allow it to use unprivileged user namespaces.
Thus I took the given /opt/google.chrome.chrome example and adopt to opt.docker-desktop.bin.com.docker.backend:
sudo nano /etc/apparmor.d/opt.docker-desktop.bin.com.docker.backend
Add the following content:
abi <abi/4.0>,
include <tunables/global>
/opt/docker-desktop/bin/com.docker.backend flags=(default_allow) { userns,
Site-specific additions and overrides. See local/README for details.
include if exists <local/opt.docker-desktop.bin.com.docker.backend> }
Restart apparmor.service
sudo systemctl restart apparmor.service
et voila, you own Docker-Desktop on 24.04 LTS without throwing unprivileged user namespaces into the trough for everyone
As indicated by the official Docker Documentation, Docker Desktop is not yet officially supported on Ubuntu 24.04.
Docker has a note in their documentation stating:
The latest Ubuntu 24.04 LTS is not yet supported. Docker Desktop will fail to start. Due to a change in how the latest Ubuntu release restricts the unprivileged namespaces, sudo sysctl -w kernel.apparmor_restrict_unprivileged_userns=0 needs to be run at least once. Refer to the Ubuntu Blog for more details.
One would assume that support would be introduced shortly after the release of a new LTS version, but since I have no idea how Docker conduct their business time will have to tell.
Wait until 24.04 is officially supported from Docker.
Artur Meinild
  • 31,035
-1
I made a service to do it automatically on reboot.
https://gist.github.com/suman-somu/5ff041537516d1e84eb6f43e616d5627
Creating a new systemd service file:
sudo nano /etc/systemd/system/set-apparmor-restrict.service
[Unit]
Description=Disable AppArmor Restriction on Unprivileged User Namespaces
[Service] Type=oneshot ExecStart=/sbin/sysctl -w kernel.apparmor_restrict_unprivileged_userns=0 RemainAfterExit=true
[Install] WantedBy=multi-user.target
Reload systemd and enable the service:
sudo systemctl daemon-reload
sudo systemctl enable set-apparmor-restrict.service
Start the service immediately (optional):
sudo systemctl start set-apparmor-restrict.service
For deleting the service:
Disable the service:
sudo systemctl disable set-apparmor-restrict.service
Remove the service file:
sudo rm /etc/systemd/system/set-apparmor-restrict.service
Reload systemd:
ti7
  • 209
-1
If you can avoid Docker Desktop and use the normal version instead, your life will be easier!
sudo apt install docker.io
sudo usermod -aG docker $USER  # add current user to docker group
# sudo reboot (not strictly required, but avoids permissions woes)
ti7
  • 209
