Balena Etcher is not opening in Ubuntu 24.04. How to run it? I am using the appimage. Other appimages are not working either.
Asked
Active
Viewed 1.4k times
17
Due to recent changes in apparmor, none of the electron apps (except VS Code) work out of the box in Ubuntu 24.04.
Temporary solution: The workaround is to run the following command.
sudo sysctl -w kernel.apparmor_restrict_unprivileged_userns=0
It has to be run again after rebooting.
To make it permanent, run the command
echo 'kernel.apparmor_restrict_unprivileged_userns = 0' |
sudo tee /etc/sysctl.d/20-apparmor-donotrestrict.conf
Note: Disabling the apparmor restrictions in 24.04 does not make it more vulnerable than 22.04. Please read this for more details, and use it at your own risk.
Archisman Panigrahi
- 38,814
