I'm trying to set the static IP of a network interface on a server that has just upgraded its distro from 20.04 to 22.04. Here is the netplan /etc/netplan/80_netplan_netcfg.yaml.
network:
  version: 2
  renderer: networkd
  ethernets:
    eno3:
      dhcp4: no
      addresses: [ 169.254.20.1/16 ]
The command sudo netplan apply doesn't seem to be able to assign the static IP to eno3 anymore. Here's the output of ip a:
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
       valid_lft forever preferred_lft forever
    inet6 ::1/128 scope host
2: eno3: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
    link/ether a8:a1:59:f2:c4:5d brd ff:ff:ff:ff:ff:ff
    altname enp4s0f0
    inet6 2401:fa00:480:4029:aaa1:59ff:fef2:c45d/64 scope global dynamic mngtmpaddr noprefixroute
       valid_lft 2591429sec preferred_lft 604229sec
    inet6 fe80::aaa1:59ff:fef2:c45d/64 scope link
I've tried manually setting the static ip using ip a add 169.254.20.1/16 dev eno3 which initially succeeds in assigning the ip address, but somehow gets unassigned after a period of time. I'm not sure if some background process would be responsible for this, but ideally I would be able to do this with netplan.
I've been scratching my head all day about this, so any help would be appreciated!
You could use
sudo netplan try
and
sudo netplan --debug apply
to find any errors.
Sometimes
sudo systemctl restart systemd-networkd
might also help to solve the problem.
