Hi I have a question in this problem.
My desktop moniter resolution is weird, so I fixed it once, and the Wi-Fi is disconnected and it says "NO Wi-Fi adapter found." First of all, when I tried to install the driver, I learned through Google that firmware and modules must be installed together. But there was one problem. The firmware appears to be installed, but the command does not work when you try to load the module. What should I do in this situation?
I checked the https://community.intel.com/t5/Wireless/AX200-unable-to-detect-WiFi-Network/m-p/1225944 provided by Intel, I found 46,48,50,53,55,59,62,63,66,67,68,71,72,73.ucode exists in the /lib/firmware file, but i didn't use the 'mokutil' method. Is it okay if I try this method?
Or I looked for other ideas.
When I checked $dpkg -l | grep linux-modules , there are currently modules that are the same as the Linuxkernel version. Then, isn't it installed? However, there was no extra module. So, is this the problem?
(base)sohyeon@X11DAi-N:/usr$ ls
bin games lnclude lib lib32 lib64 libexec libx32 local sbin share src
(base)sohyeon@X11DAi-N:/usr$ cd lib
(base)sohyeon@X11DAi-N:/usr/lib$ ls
~~~ firmware ~~~
(base)sohyeon@X11DAi-N:/usr/lib$ cd firmware/
(base)sohyeon@X11DAi-N:/usr/lib/firmware$ ls
iwlwifi-1000-5.ucode iwlwifi-100-5.ucode ~~~ iwlwifi-cc-a0-46.ucode
iwlwifi-cc-a0-48.ucode iwlwifi-cc-a0-50.ucode iwlwifi-cc-a0-53.ucode
iwlwifi-cc-a0-55.ucode iwlwifi-cc-a0-59.ucode iwlwifi-cc-a0-62.ucode
iwlwifi-cc-a0-63.ucode iwlwifi-cc-a0-66.ucode iwlwifi-cc-a0-67.ucode
iwlwifi-cc-a0-68.ucode iwlwifi-cc-a0-71.ucode iwlwifi-cc-a0-72.ucode
iwlwifi-cc-a0-73.ucode iwlwifi-so-a0-gf4-a0.pnvm iwlwifi-so-a0-gf-a0.pnvm
iwlwifi-ty-a0-gf-a0.pnvm ~~~
(base)sohyeon@X11DAi-N:~$ which mokutil
/usr/bin/mokutil
(base)sohyeon@X11DAi-N:/usr/bin$ cd mokutil
bash: cd: mokutil: Not a directory
(base)sohyeon@X11DAi-N:~$ lsmod | grep iwlwifi
(base)sohyeon@X11DAi-N:~$ dpkg -l | grep linux-modules
rc linux-modules-5.13.0-44-generic 5.13.0-44.49~20.04.1 amd64 Linux kernel extra modules for version 5.13.0 on 64 bit x86 SMP
ii linux-modules-6.2.0-32-generic 6.2.0-32~32.22.04.1 amd64 Linux kernel extra modules for version 6.2.0 on 64 bit x86 SMP
ii linux-modules-6.2.0-35-generic 6.2.0-35~35.22.04.1 amd64 Linux kernel extra modules for version 6.2.0 on 64 bit x86 SMP
rc linux-modules-extra-6.2.0-31-generic 6.2.0-31.31~22.04.1 amd64 Linux kernel extra modules for version 6.2.0 on 64 bit x86 SMP
ii linux-modules-extra-6.2.0-32-generic 6.2.0-32.32~22.04.1 amd64 Linux kernel extra modules for version 6.2.0 on 64 bit x86 SMP
(base)sohyeon@X11DAi-N:~$ nmcli dev wifi list
(base)sohyeon@X11DAi-N:~$ lspci -nnk | grep 0280 -A3
86:00.0 Network controller [0280]: Intel Corporation Wi-Fi 6 AX200 [8086:2723] (rev 1a)
Subsystem: Intel Corporation Wi-Fi 6 AX200NGW [8086:0084]
ae:00.0 PCI bridge [0604]: Intel Corporation Sky Lake-E PCI Express Root Port A [8086:2030] (rev 07)
Kernel driver in use: pcieport
(base)sohyeon@X11DAi-N:~$ uname -r
6.2.0-35-generic
(base)sohyeon@X11DAi-N:~$ lsb_release -a
NO LSB modules are available.
Distributor ID: ubuntu
Description: Ubunu 22.04.2 LTS
Release: 22.04
Codename: Jammy
(base)sohyeon@X11DAi-N:~$ sudo modprobe iwlwifi
[sudo] password for sohyeon:
modprobe: ERROR: ../libkmod/libkmod-module.c:838 kmod_module_insert_module() could not find module by name='iwlwifi'
modprobe: ERROR: could not insert 'iwlwifi': Unknown symbol in module, or unknown parameter(see dmesg)
(base)sohyeon@X11DAi-N:~$ apt search iwlwifi
backport-iwlwifi-dkms/jammy-updates,jammy-updates,jammy-security,jammy-security 9858-0ubuntu3.3 all [upgradable from: 8324-0ubuntu3~20.04.5]
iwlwifi driver backport in DKMS format
linux-modules-iwlwifi-6.2.0-34-generic/jammy-updates,jammy-security 6.2.0-34.34~22.04.1 amd64
Linux kernel iwlwifi modules for version 6.2.0-34
linux-modules-iwlwifi-6.2.0-35-generic/jammy-updates,jammy-security 6.2.0-35.35~22.04.1 amd64
Linux kernel iwlwifi modules for version 6.2.0-35
linux-modules-iwlwifi-generic/jammy-updates,jammy-security 5.15.0.87.84 amd64
Extra drivers for iwlwifi for the generic flavour
