Note: if you're using a shell other than Bash or Zsh, you may need to replace (in a more portable fashion) |& with 2>&1 |
You can wrap the whole script in braces and pipe the output to tee.
Bash provides two ways to group a list of commands to be executed as a
unit. When commands are grouped, redirections may be applied to the
entire command list. For example, the output of all the commands in
the list may be redirected to a single stream. [...] Placing a list of
commands between curly braces causes the list to be executed in the
current shell context. No subshell is created. The semicolon (or
newline) following list is required.
This first example is to be used only in case you want to log just stdout, and in case errors aren't of concern; see the second example for a better solution (this example has the adverse / wanted effect of not preserving stderr in the output file, and the adverse effect of not preserving the order of stdout / stderr in the terminal, in general I suggest you just use the second method which will Just Work(tm).
#!/usr/bin/env bash
echo foo
echo bar
} | tee log.log
exit 0
~ % ./script.sh
foo
bar
~ % cat log.log
foo
bar
This will log both stdout and stderr, with no side effects:
#!/usr/bin/env bash
echo foo
echo bar
echo error >&2
} |& tee log.log
exit 0
~ % ./script.sh
foo
bar
error
~ % cat log.log
foo
bar
error
@bizmutowyszymon's answer is just better if you want to log everything (the whole script, both stdout and stderr) both to the terminal and to the file; an advantage to using this method is that you can selectively decide which groups of commands to send to which:
#!/usr/bin/env bash
echo This part shall be printed both to the terminal and to
echo the
echo file >&2
} |& tee log.log
echo But this part shall be printed only to the
echo terminal >&2
{ echo Here we output again to the both; } |& tee -a log.log
echo And this will just be printed to the file >>log.log
exit 0
~ % ./script.sh
the
file
terminal
~ % cat log.log
the
file
