I need to set some secondary config options to a service charm deployed with juju. All of the options needed are preset to empty in the original config.yaml file. Now, some of those settings are changed in a separate config file named extra-config.yaml. How does one set these file config options to the service charm with the config-changed hook triggering? Also, can the extra-config.yaml be placed outside the charms directory structure?
This command works, but the config-changed hook is not triggered -->
juju set --config precise/cool-charm/extra-config.yaml cool-charm
Note: The docs provide a --file option which is not recognized.
Well, it is working as of now (6-21-12) with the current beta version of juju. One needs to issue a
juju set charm-name --config /path/to/extra-config.yaml
It is important to change the config file or add a revision field for the config-changed hook to trigger. The hook will not trigger if the extra config file was previously set and is unchanged.
this looks like a bug from what I can tell. Just filed it as https://bugs.launchpad.net/juju/+bug/1015645
m_3
  • 1,251
