I have a problem with installing Lubuntu on my Trekstor Surftab twin 11.6, the problem is that the BIOS won't boot from the USB (I used Rufus). I even tried to disable safe boot and changing the boot order. Someone can help? Thanks :)
Asked
Active
Viewed 295 times
Sounds like the problem I had with my Microsoft Surface Go. Have you tried using Ventoy? It's software you can put on a USB drive which allows multiple ISOs on the same drive. Additionally, if you have already got Linux on it you might be able to set the boot order from the command prompt by using the efibootmgr command. This also worked on the Surface Go. Come back to me if I can help any further.
Guy
- 116
