I have upgraded Ubuntu from 20.04lts to 22.04lts. However it seems that gcc, g++ and gfortran have disappeared from the system. I have tried:
sudo apt install gcc
but got the error:
Reading package lists... Done
Building dependency tree... Done
The following packages have unmet dependencies: cpp-11 : Depends: gcc-11-base (= 11.4.0-1ubuntu1~22.04) but 11.4.0-2ubuntu1~20.04 is to be installed gcc-11 : Depends: gcc-11-base (= 11.4.0-1ubuntu1~22.04) but 11.4.0-2ubuntu1~20.04 is to be installed Depends: libgcc-11-dev (= 11.4.0-1ubuntu1~22.04) but it is not going to be installed E: Unable to correct problems, you have held broken packages.
I have tried
sudo apt install gcc-11-base
But it says that it is already installed to the latest version and trying to install libgcc-11-dev leads to a seemingly never-ending chain of unmet dependencies.
What should I do?
EDIT As requested this is the output of policy gcc-11-base
gcc-11-base:
  Installed: 11.4.0-2ubuntu1~20.04
  Candidate: 11.4.0-2ubuntu1~20.04
  Version table:
 *** 11.4.0-2ubuntu1~20.04 100
        100 /var/lib/dpkg/status
     11.4.0-1ubuntu1~22.04 500
        500 http://it.archive.ubuntu.com/ubuntu jammy-updates/main amd64 Packages
        500 http://security.ubuntu.com/ubuntu jammy-security/main amd64 Packages
     11.2.0-19ubuntu1 500
        500 http://it.archive.ubuntu.com/ubuntu jammy/main amd64 Packages
mattiav27
  • 927
  • 27
