I have a failed Ubuntu-pro installation on a 20.04 LTS (accidentally pressed the marketing button on the software updater), and now efforts to rectify this issue lead to dependency conflicts between ubuntu-advantage-tools and ubuntu-pro-clients. Has anyone encountered this same issue and is there an obvious fix? Aptitude runs for a few hours and then stalls.
~$ sudo apt-get upgrade
Reading package lists... Done
Building dependency tree
You might want to run 'apt --fix-broken install' to correct these.
 ubuntu-advantage-tools : Depends: ubuntu-pro-client (>= 31.2~20.04) but it is not installed
 ubuntu-pro-client-l10n : Depends: ubuntu-pro-client (= 31.2~20.04) but it is not installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
$ sudo apt --fix-broken install Reading package lists... Done Building dependency tree
Reading state information... Done Correcting dependencies... Done The following additional packages will be installed: ubuntu-pro-client The following NEW packages will be installed: ubuntu-pro-client 0 upgraded, 1 newly installed, 0 to remove and 55 not upgraded. 2 not fully installed or removed. Need to get 0 B/196 kB of archives. After this operation, 1,116 kB of additional disk space will be used. Do you want to continue? [Y/n] y (Reading database ... 413409 files and directories currently installed.) Preparing to unpack .../ubuntu-pro-client_31.2~20.04_amd64.deb ... Unpacking ubuntu-pro-client (31.2~20.04) ... dpkg: error processing archive /var/cache/apt/archives/ubuntu-pro-client_31.2~20.04_amd64.deb (--unpack): trying to overwrite '/etc/apt/apt.conf.d/20apt-esm-hook.conf', which is also in package ubuntu-advantage-tools 31.2~20.04 dpkg-deb: error: paste subprocess was killed by signal (Broken pipe) Errors were encountered while processing: /var/cache/apt/archives/ubuntu-pro-client_31.2~20.04_amd64.deb E: Sub-process /usr/bin/dpkg returned an error code (1)
EDIT: This is not resolved by the suggested fix of removing ubuntu-advantage-tools as this feature is not readily removed.
dpkg: error processing package ubuntu-advantage-tools (--purge):
 dependency problems - not removing
Toby B
