Im using a hp laptop with UEFI . When i turn on my laptop Ubuntu doesn't start automatically and i have to select it manually from the boot options menu every time and its getting annoying. I'm not using dual boot and secure boot.
Asked
Active
Viewed 296 times
You could make GRUB to save you last selection. Open (as sudo)
nano /etc/default/grub
and add these two lines:
GRUB_DEFAULT=saved
GRUB_SAVEDEFAULT=true
Update grub with
sudo update-grub
You will have to select the entry once more after reboot (for Grub to save it) and then you should be good.
More info about those commands can be found in the grub official documentation
kanehekili
- 7,426
