Note
If you’d like a
requirements.txtoutput of the lockfile, run$ pipenv lock -r. This will include all hashes, however (which is great!). To get arequirements.txtwithout hashes, use$ pipenv run pip freeze.
According to the above pipenv notice, if you’d like a requirements.txt output of the lockfile, you should run $ pipenv lock -r. However, the -r options does not exist:
$ pipenv lock -r
Usage: pipenv lock [OPTIONS]
Try 'pipenv lock -h' for help.
$ pipenv lock -h
Generates Pipfile.lock.
Options:
--categories TEXT
--dev-only Emit development dependencies only (overrides
--dev)
-d, --dev Generate both develop and default requirements [env
var: PIPENV_DEV]
--extra-pip-args TEXT
--pre Allow pre-releases.
--python TEXT Specify which version of Python virtualenv should
use.
--clear Clears caches (pipenv, pip). [env var: PIPENV_CLEAR]
-q, --quiet Quiet mode.
-v, --verbose Verbose mode.
--pypi-mirror TEXT Specify a PyPI mirror.
-h, --help Show this message and exit.
May I know the command to get the requirements.txt output of the pipenv lockfile?
