I have a ssd with very important data in my workstation.
It has a ext4 and a ntfs partition.
This morning, the ext4 partition (sda1) didn't mount, and the filesystem was listed as "unknown" in the Disks application. running file -s /dev/sda1 returns "no read permissions"; Overall assessment is marked as "Disk is OK, one bad sector", but attempting to perform any smart self-test returns the error "sk_disk_open: input/output error (udisks-error-quark, 0)".
Now the ntfs partition is also listed as unknown.
Please help. I don't know what to do!
Additional info:
The disk is a Samsung 870 Evo.
It has important files and a Windows virtual machine that has been glitchy lately.
There was also a power failure recently. Not sure if it's related.
System specs:
System:
Kernel: 6.5.0-21-generic x86_64 bits: 64 compiler: N/A
Desktop: Cinnamon 5.2.7 tk: GTK 3.24.33 vt: 2 dm: GDM3 42.0
Distro: Ubuntu 22.04.4 LTS (Jammy Jellyfish)
Machine:
Type: Desktop System: MSI product: MS-7885 v: 1.0
serial: <superuser required>
Mobo: MSI model: X99A SLI PLUS(MS-7885) v: 1.0
serial: <superuser required> UEFI-[Legacy]: American Megatrends v: 1.E0
date: 06/15/2018
Drives:
Local Storage: total: 3.18 TiB used: 1.63 TiB (51.1%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 980 PRO 1TB
size: 931.51 GiB speed: 63.2 Gb/s lanes: 4 type: SSD serial: <filter>
rev: 3B2QGXA7 temp: 42.9 C scheme: MBR
ID-2: /dev/sdb vendor: Western Digital model: WD2003FZEX-00SRLA0
size: 1.82 TiB speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter>
rev: 1A01 scheme: GPT
ID-3: /dev/sdc vendor: Samsung model: SSD 860 EVO 500GB size: 465.76 GiB
speed: 6.0 Gb/s type: SSD serial: <filter> rev: 4B6Q scheme: MBR
Partition:
ID-1: / size: 301.86 GiB used: 137.26 GiB (45.5%) fs: ext4 dev: /dev/sdc2
ID-2: /mnt/hdd size: 1.82 TiB used: 1.2 TiB (66.2%) fs: ntfs
dev: /dev/sdb2
ID-3: /mnt/mint size: 795.67 GiB used: 295.74 GiB (37.2%) fs: ext4
dev: /dev/nvme0n1p2
ID-4: /mnt/nas size: 10.46 TiB used: 7.31 TiB (69.9%) fs: cifs
dev: /dev/Aether
Swap:
ID-1: swap-1 type: partition size: 30.52 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sdc3
edit:
vapor@neon:~$ sudo fdisk -l /dev/sd?
[sudo] password for vapor:
fdisk: cannot open /dev/sda: No such file or directory
Disk /dev/sdb: 1.82 TiB, 2000398934016 bytes, 3907029168 sectors
Disk model: WDC WD2003FZEX-0
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: gpt
Disk identifier: 0E6D35B6-9595-4967-A9D4-F0C206EF08D7
Device Start End Sectors Size Type
/dev/sdb1 34 262177 262144 128M Microsoft reserved
/dev/sdb2 264192 3907028991 3906764800 1.8T Microsoft basic data
Partition 1 does not start on physical sector boundary.
Disk /dev/sdc: 465.76 GiB, 500107862016 bytes, 976773168 sectors
Disk model: Samsung SSD 860
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0xaea8f6b3
Device Boot Start End Sectors Size Id Type
/dev/sdc1 * 2048 268437503 268435456 128G 7 HPFS/NTFS/exFAT
/dev/sdc2 268437504 912771071 644333568 307.2G 83 Linux
/dev/sdc3 912773120 976773167 64000048 30.5G 82 Linux swap / Solaris
