I cloned this repo on WSL2 https://github.com/apache/airflow/blob/main/dev/breeze/doc/01_installation.rst#docker-in-wsl-2 and tried to build a docker image that uses also this script https://github.com/apache/airflow/blob/main/scripts/docker/install_os_dependencies.sh, but this error appears: ERROR [main 4/34] RUN bash /scripts/docker/install_os_dependencies.sh dev 0.7s [main 4/34] RUN bash /scripts/docker/install_os_dependencies.sh dev: : invalid option name/install_os_dependencies.sh: line 2: set: pipefail
pipefail error
I found from this question set: pipefail failing on WSL windows 11 ubuntu 22.04.3 that the problem is that the file is not Linux formatted. I thought that WSL is POSIX compliant, but apparently it is not.
I reformatted the file to unix with dos2unix, library suggested in that question, but it still throws this error.
Please help, cause I am stuck. Also, is there any way to do the WSL folders to be POSIX compliant?
Thank you!
criss
