Running Ubuntu server 22.04.4 LTS.
Today I did an apt update and apt upgrade which ran through a few updates, and then I pulled new docker images via docker-compose pull. After I tried to restart the containers via docker-compose, I got a bunch of errors regarding container config and many of the containers refused to start. Then when I run docker ps -a, I see a bunch of the container names have changed to include a random string of characters before the prior name (e.g. swag is now 5f6bfe94c235_swag). I didn't change anything in the docker-compose.yml file and it had been working fine before this.
When I run sudo docker-compose up -d, I get the following output:
Traceback (most recent call last):
File "/usr/bin/docker-compose", line 33, in <module>
sys.exit(load_entry_point('docker-compose==1.29.2', 'console_scripts', 'docker-compose')())
File "/usr/lib/python3/dist-packages/compose/cli/main.py", line 81, in main
command_func()
File "/usr/lib/python3/dist-packages/compose/cli/main.py", line 203, in perform_command
handler(command, command_options)
File "/usr/lib/python3/dist-packages/compose/metrics/decorator.py", line 18, in wrapper
result = fn(*args, **kwargs)
File "/usr/lib/python3/dist-packages/compose/cli/main.py", line 1186, in up
to_attach = up(False)
File "/usr/lib/python3/dist-packages/compose/cli/main.py", line 1166, in up
return self.project.up(
File "/usr/lib/python3/dist-packages/compose/project.py", line 697, in up
results, errors = parallel.parallel_execute(
File "/usr/lib/python3/dist-packages/compose/parallel.py", line 108, in parallel_execute
raise error_to_reraise
File "/usr/lib/python3/dist-packages/compose/parallel.py", line 206, in producer
result = func(obj)
File "/usr/lib/python3/dist-packages/compose/project.py", line 679, in do
return service.execute_convergence_plan(
File "/usr/lib/python3/dist-packages/compose/service.py", line 579, in execute_convergence_plan
return self._execute_convergence_recreate(
File "/usr/lib/python3/dist-packages/compose/service.py", line 499, in _execute_convergence_recreate
containers, errors = parallel_execute(
result = func(obj)
File "/usr/lib/python3/dist-packages/compose/service.py", line 494, in recreate
return self.recreate_container(
File "/usr/lib/python3/dist-packages/compose/service.py", line 612, in recreate_container
new_container = self.create_container(
File "/usr/lib/python3/dist-packages/compose/service.py", line 330, in create_container
container_options = self._get_container_create_options(
File "/usr/lib/python3/dist-packages/compose/service.py", line 921, in _get_container_create_options
container_options, override_options = self._build_container_volume_options(
File "/usr/lib/python3/dist-packages/compose/service.py", line 960, in _build_container_volume_options
binds, affinity = merge_volume_bindings(
File "/usr/lib/python3/dist-packages/compose/service.py", line 1548, in merge_volume_bindings
old_volumes, old_mounts = get_container_data_volumes(
File "/usr/lib/python3/dist-packages/compose/service.py", line 1579, in get_container_data_volumes
container.image_config['ContainerConfig'].get('Volumes') or {}
KeyError: 'ContainerConfig'
I'm able to manually start the containers by using the command:
sudo docker start <container_name>
Restarting the docker service and restarting the computer didn't fix it. Any idea what broke with this update and how I can fix it?
