Any request like sudo apt-get install *** starts the installation process, but when unpacking it throws an error, after which some packages are installed and work fine, some do not work fine, and some do not show up as installed.
dpkg: error processing package openmpi-bin (--configure):
 installed openmpi-bin package post-installation script subprocess returned error exit status 2
dpkg: dependency problems prevent configuration of mpi-default-bin:
 mpi-default-bin depends on openmpi-bin; however:
  Package openmpi-bin is not configured yet.
dpkg: error processing package mpi-default-bin (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of libcoarrays-openmpi-dev:amd64: libcoarrays-openmpi-dev:amd64 depends on openmpi-bin; however: Package openmpi-bin is not configured yet.
dpkg: error processing package libcoarrays-openmpi-dev:amd64 (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of libopenmpi-dev:amd64: libopenmpi-dev:amd64 depends on openmpi-bin (>= 3.0.0-1); however: Package openmpi-bin is not configured yet.
dpkg: error processing package libopenmpi-dev:amd64 (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of libboost-mpi-python1.74.0: libboost-mpi-python1.74.0 depends on mpi-defauNo apport report written because the error message indicates it's a follow-up error from a previous failure. No apport report written because the error message indicates it's a follow-up error from a previous failure. No apport report written because MaxReports has already been reached No apport report written because MaxReports has already been reached lt-bin; however: Package mpi-default-bin is not configured yet.
dpkg: error processing package libboost-mpi-python1.74.0 (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of libboost-mpi-python1.74-dev: libboost-mpi-python1.74-dev depends on libboost-mpi-python1.74.0 (= 1.74.0-14ubuntu3); however: Package libboost-mpi-python1.74.0 is not configured yet.
dpkg: error processing package libboost-mpi-python1.74-dev (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of libboost-mpi-python-dev: libboost-mpi-python-dev depends on libboost-mpi-python1.74-dev; however: Package libboost-mpi-python1.74-dev is not configured yet.
dpkg: error processing package libboost-mpi-python-dev (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of libboost-all-dev: libboost-all-dev depends on libboost-mpi-python-dev; however: PackageNo apport report written because MaxReports has already been reached No apport report written because MaxReports has already been reached No apport report written because MaxReports has already been reached libboost-mpi-python-dev is not configured yet.
dpkg: error processing package libboost-all-dev (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of mpi-default-dev: mpi-default-dev depends on libopenmpi-dev; however: Package libopenmpi-dev:amd64 is not configured yet.
dpkg: error processing package mpi-default-dev (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of libboost-mpi1.74-dev: libboost-mpi1.74-dev depends on mpi-default-dev; however: Package mpi-default-dev is not configured yet.
No apport report written because MaxReports has already been reached No apport report written because MaxReports has already been reached dpkg: error processing package libboost-mpi1.74-dev (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of libboost-mpi-dev: libboost-mpi-dev depends on libboost-mpi1.74-dev; however: Package libboost-mpi1.74-dev is not configured yet.
dpkg: error processing package libboost-mpi-dev (--configure): dependency problems - leaving unconfigured No apport report written because MaxReports has already been reached Errors were encountered while processing: openmpi-bin mpi-default-bin libcoarrays-openmpi-dev:amd64 libopenmpi-dev:amd64 libboost-mpi-python1.74.0 libboost-mpi-python1.74-dev libboost-mpi-python-dev libboost-all-dev mpi-default-dev libboost-mpi1.74-dev libboost-mpi-dev E: Sub-process /usr/bin/dpkg returned an error code (1)
I tried the following:
sudo apt clean
sudo dpkg --configure -a
sudo apt -f install
sudo dpkg --remove --force-remove-reinstreq openmpi-bin
sudo apt update
sudo apt install openmpi-bin
sudo apt autoremove
sudo apt update && sudo apt upgrade
But sudo dpkg --remove --force-remove-reinstreq openmpi-bin answer:
dpkg: dependency problems prevent removal of openmpi-bin:
 mpi-default-bin depends on openmpi-bin.
 libopenmpi-dev:amd64 depends on openmpi-bin (>= 3.0.0-1).
 libcoarrays-openmpi-dev:amd64 depends on openmpi-bin.
dpkg: error processing package openmpi-bin (--remove): dependency problems - not removing Errors were encountered while processing: openmpi-bin
This answer from this and this also can not help me.
sudo apt-get clean
sudo apt-get update
sudo apt-get upgrade
sudo apt-get install -f
I tried everything from apt update to restart. What can I do to remove this error and install packages correctly?
Mark
I just ran into the same error. I was able to solve it by doing:
sudo rm -f /etc/alternatives/mpi* /var/lib/dpkg/alternatives/mpi*
sudo rm /var/lib/dpkg/alternatives/mpi
Then I could install whatever I was trying to install before (gparted in my case)
Credits to: https://stackoverflow.com/questions/62464085/openmpi-bin-error-after-update-kubuntu-18-04-to-20-04
kristyna
  • 101
