Welcome Srecko to the forum.
I'm using Google translate to see this in English. Hopefully we can communicate okay like this.
Problem
The public key for the ProtonVPN repository is missing, causing the signature verification to fail.
Manufacturer's Instructions
I think they are not following standard process, which makes this difficult. However, if you follow steps 1 through 4 it might resolve your issue.
Ref: https://protonvpn.com/support/official-linux-vpn-mx-linux/
- Install the Proton VPN repository
Just double-click the downloaded DEB file and follow the prompts given
by your default package manager (or right click →Install Deb files on
the Xfce desktop).
Please don’t try to check the GPG signature of this release package
(dpkg-sig –verify). Our internal release process is split into several
part and the release package is signed with a GPG key, and the repo is
signed with another GPG key. So the keys don’t match.
If you want to check the repo package integrity, you can check its
checksum with the following command:
echo "c68a0b8dad58ab75080eed7cb989e5634fc88fca051703139c025352a6ee19ad protonvpn-stable-release_1.0.3-2_all.deb" | sha256sum --check -
The remainder of this answer is informational.
GPG Missing Key Errors
Here's how to verify the PKI public key when GPG shows it as missing.
- Start with the Source
I'm unable to use curl to list repo.protonvpn.com/debian/ directory, but you can view it in the web browser: https://repo.protonvpn.com/debian/. The public key is there.
- Key ID
The Key ID is derived from the Public Key. Here's how to download it and then derive:
wget -O protonvpn_public_key.asc https://repo.protonvpn.com/debian/public_key.asc
gpg --import --with-fingerprint protonvpn_public_key.asc
It matches the output you gave in the post.
gpg: key 4EDE055B645F044F: public key "Proton Technologies AG
opensource@proton.me" imported
GPG Explanation
Debian and Ubuntu both utilize GPG (GNU Privacy Guard) for package management and maintenance. It performs these functions:
- Package Signing
- Repository Verification
- Key Management
- Security Enhancements
The error is saying the software cannot be updated (or maintained) because GPG cannot find the key to verify it's security. The Ubuntu Repository configuration must point to the correct URL so that it can find the public key.
Configuration:
Repository configurations are in the file
/etc/apt/sources.list and the directory /etc/apt/sources.list.d/
(within another files).
Key Location:
So you have to make sure your computer's configuration is pointed to the right place.
Logs
A great resource for finding a root cause are logs. For this issue the APT logs are most applicable.
tail -n 100 /var/log/apt/history.log
cat /var/log/apt/history.log | grep -E -i "error|refused|failed|proton"
sudo grep -E -i "error|refused|failed|proton" /var/log/apt/history.log /var/log/auth.log /var/log/syslog /var/log/dpkg.log
