I tried to install the newest version of Python in my Ubuntu laptop. When I finished installing it, I realized that my Terminal and some other apps were gone. They were not among my favorites where I had them and I searched for them and they were gone.
I restarted my laptop to see if that fixed the problem. When it turned on, it automatically went to tty terminal.
I searched online and I found this forum so I run:
sudo apt-get remove --purge gnome-terminal
and:
sudo apt-get install gnome-terminal
However, I got:
update-notifier-common
Sub-process /usr/bin/dpkg returned an error code (1)
I searched online and I tried running all solutions in this article one by one:
sudo apt remove --purge update-notifier-common
Once I did this, the Sub-process error disappeared and I (apparently) was able to install the Terminal again, but now it does not open.
Again, in the tty terminal I run:
gnome-terminal --version
And it says:
Traceback (most recent call last):
File "/usr/bin/gnome-terminal", line 9, in <module>
from gi.repository import GLib, Gio
ModuleNotFoundError: No module named 'gi'
For this issue I found this thread from 7 years ago. Some of the solutions given there are not recommended by other users, so I avoided them. From this thread, I tried the following:
sudo update-alternatives --config python3
and it said:
update-alternatives: error: no alternatives for python 3
At this point, I don't know what else to do. The last thread seems a bit outdated. Can anyone help me with some updated solutions? I'd appreciate it.
Elena
Seems like your system missing the gi.repository python module. You need to install it.
sudo apt install python3-gi
