I'm looking for an offline speech recognition software that would work for all Linux apps. The ideal solution would be just like the VS Code Speech extension:
  1. Hold a shortcut
  2. Speak
  3. Release shortcut
  4. Text is inserted at caret position
The other answers I saw here are old, referring to now unsupported packages (or online for the google one):
JM Lord
  • 133
  • I’ve found nerd-dictation to be the most suitable solution. It uses VOSK’s offline models to perform speech‑to‑text conversion.
  • You can see it here.
  • To integrate it into your workflow, bind the nerd-dictation begin and nerd-dictation end commands to separate hotkeys via Settings → Keyboard → Keyboard Shortcuts → Custom Shortcuts.
  • If you prefer “hold‑to‑dictate” behavior, you can install a utility like xbindkeys and configure it to run begin on key‑down and end on key‑up.
Mr_Sure21
  • 26
