In this context, shells uses glob patterns, not regular expressions1. In bash, you could use a ksh-style extended glob (enabled by default in an interactive bash shell - in a script, you will need to set with shopt -s extglob):
ls test@([13][0-8]|2[23])
or
ls test@(1[0-8]|2[23]|3[0-8])
In zsh, you could use numeric ranges instead (although it supports ksh-style extended globs as well):
ls test(<10-18>|<22-23>|<30-38>)
Alternatively, you could use brace expansion (in both bash and zsh) - but note this doesn't actually perform matching so you will get errors unless all the named files are actually present:
ls test{{1,3}{0..8},22,23}
Coincidentally, ([13][0-8]|2[23]) and (1[0-8]|2[23]|3[0-8]) are also valid extended regular expressions, so you could use them in a find expression for example:
find . -maxdepth 1 -regextype posix-extended -regex '.*/test([13][0-8]|2[23])'
