I installed NVidia current driver from ubuntu software center then i started to see that my monitor resolution is not fixed!! so that every time i log in to my machine i have to change the resolution.
but starting from yesterday, all options have been disappeared & i have one option only 640*480.
i have the problem shown in the link here: https://mooniat.files.wordpress.com/2012/06/colord.png which i think is the cause of this. Any help please, thank you in advance.
specifications: OS: ubuntu 12.04 precise laptop: Dell inspiron N5110 GPU: nvidia GeForce 525M
Thanks again, yours.
First remove current nvidia driver.
sudo apt-get remove nvidia-current
Instruction for installing Bumblebee to turn off discrete GPU and enable only when required
  1. Type the following in terminal,
    sudo add-apt-repository ppa:bumblebee/stable
    then
    sudo apt-get update
  2. To install Bumblebee using the proprietary nvidia driver:
    sudo apt-get install bumblebee bumblebee-nvidia
  3. Run following
    sudo usermod -a -G bumblebee $USER
  4. Reboot.
If you just want to disable nvidia card, no need to learn followings
Usage Instruction :
To run a program with nvidia card, use optirun command prefixed in terminal. Like to run glxspheres with nvidia card type
optirun glxspheres
To run firefox type : optirun firefox &
Note: If you intend to run 32-bit programs like Wine and using Ubuntu 11.10 Oneiric or later, install 32-bit libraries with: sudo apt-get install virtualgl-libs:i386 libgl1-mesa-glx:i386 libc6:i386
Linked Questions:
How well will Nvidia Optimus cards be supported in 12.04?
Is a NVIDIA GeForce with Optimus Technology supported by Ubuntu?
Can't use nvidia card/driver on optimus notebook
Web-E
  • 21,716
