I installed Ubuntu 22.04 in ThinkPad X1 Carbon and when I open cheese it shows "No device found". I don't think that the problem is Cheese, because when searching for a camera via terminal, it can't be found. I also checked BIOS and the camera is enabled (I can use it in Windows).
I think it must be a missing driver, so I searched for a solution. Following instructions, running sudo ubuntu-drivers list returns nothing, sudo ubuntu-drivers install returns All the available drivers are already installed and sudo apt install nvidia-fabricmanager-525 libnvidia-nscq-525 returns:
Reading package lists... Done
Building dependency tree... Done
libnvidia-nscq-525 is already the newest version (525.147.05-0ubuntu0.22.04.1).
nvidia-fabricmanager-525 is already the newest version (525.147.05-0ubuntu0.22.04.1).
0 upgraded, 0 newly installed, 0 to remove and 17 not upgraded.
Can someone help me find the missing driver or give me any tip?
lsusb returns:
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 004: ID 8086:0b63 Intel Corp. USB Bridge
Bus 003 Device 003: ID 046d:c548 Logitech, Inc. USB Receiver
Bus 003 Device 002: ID 06cb:00fc Synaptics, Inc.
Bus 003 Device 005: ID 8087:0033 Intel Corp.
Bus 003 Device 006: ID 1050:0407 Yubico.com Yubikey 4/5 OTP+U2F+CCID
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Inês
After running sudo adduser $USER video, I've followed this: Is there any way ffmpeg send video to /dev/video0 on Ubuntu?
and by running ffplay /dev/video0 I have video now.
It isn't perfect, but works. To have camera in Teams, I run that in terminal, and then turn the camera on in Teams. If someone has another solution, please share :)
Inês
