Trying to install MySQL and Workbench on Ubuntu 22.04, issues with GPG key. When running update to see if my changes have had effect I persistently get:
: An error occurred during the signature verification. The repository is not updated and the previous index files will be used.
GPG error: http://repo.mysql.com/apt/ubuntu jammy
InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY B7B3B788A8D3785C
W: Failed to fetch http://repo.mysql.com/apt/ubuntu/dists/jammy/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY B7B3B788A8D3785C
W: Some index files failed to download. They have been ignored, or old ones used instead.
I have removed and reinstalled the public key to the APT keyring, fetched the key directly from keyserver, deleted and reinstalled the repository. Any takers? Could really use some advice...
mchid
  • 44,904
  • 102
  • 162
Wes78
This is what I did to get it to work:
Get rid of MySQL, Directories, Configuration files, Repositories, GPG Keys: sudo apt purge mysql-server mysql-client mysql-common mysql-server-core-* mysql-client-core-* sudo rm -rf /var/lib/mysql/ sudo rm -rf /etc/mysql/ sudo rm /etc/apt/sources.list.d/mysql.list
Find replace MySQL.GPG key id, sudo apt-key list sudo apt-key del sudo apt update
Get .Debs from MySQL - Repositories, MySQL Server, Workbench; Download.
Extract and install
If you get unmet dependencies check version
Remove the existing version of mysql-community-client-plugins: sudo apt remove mysql-community-client-plugins
Install the required version of mysql-community-client-plugins: sudo apt install mysql-community-client-plugins=8.0.36-1ubuntu22.04
Retry installing MySQL Workbench: sudo apt install ./mysql-workbench-community-dbgsym_8.0.36-1ubuntu22.04_amd64.deb
Wes78
