I'm following these instructions for setting up sftp and scp (although I'd like to add rsync too) but when the jailed account logs in, it immediately disconnects without any errors I can see.
The doc says that if this happens you need to journalctl|grep jk_, which gives this (nor errors):
jk_chrootsh[3157425]: now entering jail /home/jail for user jailtest (1001) with arguments -c /usr/lib/openssh/sftp-server
Most if not all of the information I can find on Jailkit seems pretty old, although I see jailkit itself was updated in Oct 2021. Does anyone know if it still works on Ubuntu or how I can track down what error is happening?
I have used Jailkit successfully in the past with Ubuntu 18. I'm starting to think that something fundamental has changed in 20 (snaps, perhaps?) which has disabled Jailkit in some way.
/home/jail/etc/passwd:
jailtest:x:1001:1004:tester,,,:/home/jailtest:/usr/sbin/jk_lsh
/etc/jailkit/jk_lsh.ini:
[jailtest]
paths= /usr/bin, /usr/lib/openssh
executables= /usr/bin/scp, /usr/lib/openssh/sftp-server
ldd /usr/sbin/jk_lsh
linux-vdso.so.1 (0x00007ffce6d11000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f91ffee6000)
/lib64/ld-linux-x86-64.so.2 (0x00007f920011f000)
strace chroot /home/jail/ /usr/sbin/jk_lsh and other things doesn't seem to show anything missing.
scp -v ./test.txt jailtest@xxx.uk:/home/jailtest/ from the client shows no errors and just hangs up:
debug1: Sending environment.
debug1: channel 0: setting env LANG = "en_GB.UTF-8"
debug1: Sending subsystem: sftp
debug1: pledge: fork
debug1: client_input_channel_req: channel 0 rtype exit-status reply 0
debug1: client_input_channel_req: channel 0 rtype eow@openssh.com reply 0
debug1: channel 0: free: client-session, nchannels 1
Transferred: sent 4172, received 4132 bytes, in 0.4 seconds
Bytes per second: sent 9390.9, received 9300.9
debug1: Exit status 3
scp: Connection closed
My sshd_config is:
PermitRootLogin no
PubkeyAuthentication yes
PasswordAuthentication no
PermitEmptyPasswords no
ChallengeResponseAuthentication no
UsePAM yes
X11Forwarding yes
PrintMotd no
AcceptEnv LANG LC_*
Subsystem       sftp    /usr/lib/openssh/sftp-server
AllowGroups ssh-users # I've put the jailed user into this, removing it causes a permissions error
TommyPeanuts
  • 1,147
The short answer to this is "yes". Before I started investigting @DanielT's very good suggestions in the comments, I decided to remove and re-install the JailKit package. I then re-created my jail with:
jk_init -v -j /home/jail netutils jk_lsh
(Note that this appears different to the official documentation.)
The netutils alias in that command allows access to sftp, scp and rsync which is what I was interested in - see /etc/jailkit/jk_init.ini.
For some reason, I got a Python error when I ran the jk_init command (jailkit v2.23-1), but running it again appeared to clear the problem.
Jailed accounts were then able to log in and were chrooted correctly.
TommyPeanuts
  • 1,147
