Adding php8.2-dev package to my kubuntu 22.04 I got error with held broken packages :
root@master-at-home:/mnt/_work_sdb8/wwwroot/lar/NewsPublisher# sudo apt-get update
Hit:1 http://packages.microsoft.com/repos/code stable InRelease
Hit:2 https://dl.google.com/linux/chrome/deb stable InRelease
Hit:3 http://ua.archive.ubuntu.com/ubuntu jammy InRelease
Hit:4 https://download.docker.com/linux/ubuntu jammy InRelease
Hit:5 http://repo.mysql.com/apt/ubuntu jammy InRelease
Hit:6 https://deb.nodesource.com/node_20.x jammy InRelease
Ign:7 https://repo.mongodb.org/apt/ubuntu jammy/mongodb-org/7.0 InRelease
Hit:8 https://deb.opera.com/opera-stable stable InRelease
Hit:9 https://repo.mongodb.org/apt/ubuntu jammy/mongodb-org/7.0 Release
Hit:10 https://ppa.launchpadcontent.net/ondrej/php/ubuntu jammy InRelease
Reading package lists... Done
root@master-at-home:/mnt/_work_sdb8/wwwroot/lar/NewsPublisher# sudo apt-get upgrade
Building dependency tree... Done
Calculating upgrade... Done
The following packages were automatically installed and are no longer required:
appmenu-gtk-module-common jsonlint libappmenu-gtk3-parser0 php-composer-ca-bundle php-composer-metadata-minifier php-composer-pcre php-composer-semver php-composer-spdx-licenses php-composer-xdebug-handler
php-intl php-json-schema php-react-promise php-symfony-console php-symfony-process php-symfony-string php8.1-intl php8.2-mongodb
Use 'sudo apt autoremove' to remove them.
The following packages have been kept back:
libapache2-mod-php mysql-common mysql-server php-bz2 php-intl php-mbstring php-mcrypt php-mysql php-pgsql php-xml php8.2-mcrypt
0 upgraded, 0 newly installed, 0 to remove and 11 not upgraded.
root@master-at-home:/mnt/_work_sdb8/wwwroot/lar/NewsPublisher# sudo apt install php8.2-dev
libssl-dev : Depends: libssl3 (= 3.0.2-0ubuntu1) but 3.0.2-0ubuntu1.10 is to be installed
I tried to run a command (I found a hint in the net):
sudo aptitude install php8.2-dev
But the same error ?
In my OS I have :
uname -a
Linux master-at-home 6.2.0-35-generic #35~22.04.1-Ubuntu SMP PREEMPT_DYNAMIC Fri Oct 6 10:23:26 UTC 2 x86_64 x86_64 x86_64 GNU/Linux
apt list --installed libssl3
Listing... Done
libssl3/now 3.0.2-0ubuntu1.10 amd64 [installed,local]
libssl3/now 3.0.2-0ubuntu1.10 i386 [installed,local]
dpkg -s libssl3
Package: libssl3
Status: install ok installed
Priority: required
Section: libs
Installed-Size: 5824
Maintainer: Ubuntu Developers <ubuntu-devel-discuss@lists.ubuntu.com>
Architecture: amd64
Multi-Arch: same
Source: openssl
Version: 3.0.2-0ubuntu1.10
Depends: libc6 (>= 2.34), debconf (>= 0.5) | debconf-2.0
Description: Secure Sockets Layer toolkit - shared libraries
This package is part of the OpenSSL project's implementation of the SSL
and TLS cryptographic protocols for secure communication over the
Internet.
It provides the libssl and libcrypto shared libraries.
Homepage: https://www.openssl.org/
Original-Maintainer: Debian OpenSSL Team <pkg-openssl-devel@alioth-lists.debian.net>
How to salve the issue ?
UPDATED BLOCK :
I try to run commands under root :
master@master-at-home:/mnt/_work_sdb8/wwwroot/lar/WebsocketLaravel10$ sudo -s
[sudo] password for master:
root@master-at-home:/mnt/_work_sdb8/wwwroot/lar/WebsocketLaravel10# apt policy php8.2-common
php8.2-common:
Installed: 8.2.15-1+ubuntu22.04.1+deb.sury.org+1
Candidate: 8.2.15-1+ubuntu22.04.1+deb.sury.org+1
Version table:
*** 8.2.15-1+ubuntu22.04.1+deb.sury.org+1 500
500 https://ppa.launchpadcontent.net/ondrej/php/ubuntu jammy/main amd64 Packages
100 /var/lib/dpkg/status
But still got libssl3 dependecy error :
root@master-at-home:/mnt/_work_sdb8/wwwroot/lar/WebsocketLaravel10# apt policy php8.2-dev
php8.2-dev:
Installed: (none)
Version table:
root@master-at-home:/mnt/_work_sdb8/wwwroot/lar/WebsocketLaravel10# sudo apt install php8.2-dev
UPDATED BLOCK # 2:
php8.2-dev:
Installed: (none)
Version table:
