I downloaded and installed Citrix Workspace app 2311 for Linux.
I see it in the programs (via windows key --> type citrix)
Unfortunately it does not start.
In var/log/syslog I see the following error:
/opt/Citrix/ICAClient/selfservice: error while loading shared libraries: libwebkit2gtk-4.0.so.37: cannot open shared object file: No such file or directory
However if found this library in /snap/gnome-42-2204/141/usr/lib/x86_64-linux-gnu/libwebkit2gtk-4.0.so.37
How to fix this error?
Work around
sudo ln -s /snap/gnome-42-2204/141/usr/lib/x86_64-linux-gnu/libwebkit2gtk-4.0.so.37 /usr/lib/x86_64-linux-gnu/libwebkit2gtk-4.0.so.37
sudo ln -s /snap/gnome-42-2204/141/usr/lib/x86_64-linux-gnu/libjavascriptcoregtk-4.0.so.18 /usr/lib/x86_64-linux-gnu/libjavascriptcoregtk-4.0.so.18
sudo ln -s /snap/gnome-42-2204/141/usr/lib/x86_64-linux-gnu/libicui18n.so.70 /usr/lib/x86_64-linux-gnu/libicui18n.so.70
sudo ln -s /snap/gnome-42-2204/141/usr/lib/x86_64-linux-gnu/libicuuc.so.70 /usr/lib/x86_64-linux-gnu/libicuuc.so.70
sudo ln -s /snap/gnome-42-2204/141/usr/lib/x86_64-linux-gnu/libicudata.so.70 /usr/lib/x86_64-linux-gnu/libicudata.so.70
sudo ln -s /snap/gnome-42-2204/141/usr/lib/x86_64-linux-gnu/webkit2gtk-4.0 /usr/lib/x86_64-linux-gnu/webkit2gtk-4.0
I don't know why you are messing around with symlinks and shared libraries when you could simply do this:
sudo apt install libwebkit2gtk-4.0-37
The other libraries files will be installed together. Somehow the icaclient package lists a bunch of required dependencies as only "Recommended" possibly for compatibility, so you could have tried sudo apt install --install-recommends ./icaclient_23.11.0.82_amd64.deb or manually installed them. Anyway, the EULA window shows up, but 23.10 isn't officially supported.
Daniel T
  • 5,339
