I've got a directory that I want to be owned by multiple users on the system. That is, I want any application running as oli to think those files are owned by oli, just as any application run by jim will think the same. This is not the same as just giving permissions as I have an issue where ownership matters. I trust all users in this scenario.
My immediate thought is some sort of bind mount that translates IDs transparently, and I'm sure there's a way to do this with fuse but quick and fast (kernel level) would be preferable for me.
To be clear, I'm not looking for actual mutiple ownership, I just want multiple users to see the files as theirs. There are a few different layers I know of in Linux that can map user IDs from one to another, so one of those is probably going to do the job here.
Oli
  • 299,380
Figured out the mount options for a completely in-Kernel ID mapping. This allows you to re-mount any directory somewhere else, with a different owner/group.
sudo mount --bind -o "X-mount.idmap=u:1000:1002:1 g:1000:1002:1" /home/oli/dir /home/other/dir
Both oli and other users can write to the same set of files thinking that they're the owner. This can also be persisted fairly easily to fstab.
Another option is bindfs/FUSE:
sudo bindfs --map=oli/other:@oli/@other /home/oli/dir /home/other/dir
That offers pretty transparent ownership. The other account sees the files as their own. I'd expect this to be slower than an in-kernel mapping.
Oli
  • 299,380
Linux does not support multiple users owning filesystem objects. They must have one single owner.
This sounds like an XY problem. You think the solution is to have multiple owners, but you have not sufficiently explained the problem (you think the application cares about file ownership; why?) which could have other solutions, such as group ownership, running in a container, changing the user the application runs as, etc.
user10489
  • 5,533
Here is a solution that does not require sudo/root and works for all mounts, present or future:
# Run each line in terminal
# (this needs to be changed if you want to make this into a script)
sed -n "/^$USER:/s/$UID/65534/gp" /etc/passwd > ~/passwd
sed -n "/^$USER:/s/$UID/65534/gp" /etc/group > ~/group
unshare -mr mount --bind ~/passwd /etc/passwd mount --bind ~/group /etc/group
unshare -U your_app_here
This works by mapping the nobody and nogroup IDs to the current name. The last unshare does not set up any mappings so we become nobody and nogroup, which we rename (as well as preserve home directory and shell) with the above. I am assuming your apps are checking for the username of the files, and it is unknown whether this will break upon encountering apps that check against uid=65534. If you would let ls be your_app_here, you will see that every single file on the system looks like it's owned by you now even if you mount something later.
Daniel T
  • 5,339
