How do I fix this boot error in sda5 in Ubuntu 20.04?
Run fsck -y /dev/sda5. Afterwards, run the command exit to reboot.
The problem occurred because the computer was not properly shut down. Maybe it ran out of battery, or you had to shut it down for some reason, or something else.
You can try repairing your system in the recovery mode for Ubuntu.
To go to the recovery menu select Advanced Options for Ubuntu in the boot loader.
Then select the recovery mode option in the next screen, This should open the recovery options.
Select and run the option that says: fsck Check all file systems
You can also try repairing any broken packages using the dpkg option in the same menu.
