When waking up from hibernation, the touchpad behaves different than before hibernation. It is usable, meaning I can move the cursor, use left and right click, scroll etc. but the behaviour changed. For example, the scrolling is inverted, no more three-finger middle click, touchpad stays active during typing (really annoying). But when I open the touchpad settings, they look unchanged. In addition, the touchpad is unresponsive to changes of the touchpad settings after hibernation. The behaviour returns to normal (like i set it) after reboot.
I tried the following which couldn't resolve the problem:
  • deactivating and reactivating SynPS/2 Synaptics TouchPad (like this)
  • Installing Synaptics drivers (to use instead of the default libinput drivers) with sudo apt install xserver-xorg-input-synaptics and subsequent reboot*
I wanted to try sudo rmmod i2c_hid + sudo modprobe i2c-hid (Source) but the first command returned rmmod: ERROR: Module i2c_hid is in use by: i2c_hid_acpi and I don't know how to proceed here.
*Although this was an upgrade in my view, as Synaptics offers richer configuration options.
Making Ubuntu recognize the touchpad as a mouse is not an option for me, as I would lose even more functionality that way.
I am using an HP ProBook 450 G6 with Kubuntu 22.04.
Output of xinput list:
⎡ Virtual core pointer                          id=2    [master pointer  (3)]
⎜   ↳ Virtual core XTEST pointer                id=4    [slave  pointer  (2)]
⎜   ↳ SYNA3081:00 06CB:826F Mouse               id=10   [slave  pointer  (2)]
⎜   ↳ SYNA3081:00 06CB:826F Touchpad            id=11   [slave  pointer  (2)]
⎜   ↳ SynPS/2 Synaptics TouchPad                id=13   [slave  pointer  (2)]
⎣ Virtual core keyboard                         id=3    [master keyboard (2)]
    ↳ Virtual core XTEST keyboard               id=5    [slave  keyboard (3)]
    ↳ Power Button                              id=6    [slave  keyboard (3)]
    ↳ Video Bus                                 id=7    [slave  keyboard (3)]
    ↳ Video Bus                                 id=8    [slave  keyboard (3)]
    ↳ Sleep Button                              id=9    [slave  keyboard (3)]
    ↳ AT Translated Set 2 keyboard              id=12   [slave  keyboard (3)]
    ↳ Wireless hotkeys                          id=14   [slave  keyboard (3)]
    ↳ HP WMI hotkeys                            id=15   [slave  keyboard (3)]
Output of xinput list-props 11:
Device 'SYNA3081:00 06CB:826F Touchpad':
        Device Enabled (189):   1
        Coordinate Transformation Matrix (191): 1.000000, 0.000000, 0.000000, 0.000000, 1.000000, 0.000000, 0.000000, 0.000000, 1.000000
        Device Accel Profile (324):     1
        Device Accel Constant Deceleration (325):       2.500000
        Device Accel Adaptive Deceleration (326):       1.000000
        Device Accel Velocity Scaling (327):    12.500000
        Synaptics Edges (350):  53, 1279, 44, 784
        Synaptics Finger (351): 25, 30, 0
        Synaptics Tap Time (352):       180
        Synaptics Tap Move (353):       68
        Synaptics Tap Durations (354):  180, 180, 100
        Synaptics ClickPad (355):       1
        Synaptics Middle Button Timeout (356):  0
        Synaptics Two-Finger Pressure (357):    282
        Synaptics Two-Finger Width (358):       7
        Synaptics Scrolling Distance (359):     -31, -31
        Synaptics Edge Scrolling (360): 0, 0, 0
        Synaptics Two-Finger Scrolling (361):   1, 1
        Synaptics Move Speed (362):     1.000000, 1.750000, 0.127551, 0.000000
        Synaptics Off (363):    1
        Synaptics Locked Drags (364):   0
        Synaptics Locked Drags Timeout (365):   5000
        Synaptics Tap Action (366):     0, 0, 0, 0, 1, 3, 2
        Synaptics Click Action (367):   1, 3, 0
        Synaptics Circular Scrolling (368):     0
        Synaptics Circular Scrolling Distance (369):    0.100007
        Synaptics Circular Scrolling Trigger (370):     0
        Synaptics Circular Pad (371):   0
        Synaptics Palm Detection (372): 0
        Synaptics Palm Dimensions (373):        10, 200
        Synaptics Coasting Speed (374): 20.000000, 50.000000
        Synaptics Pressure Motion (375):        30, 160
        Synaptics Pressure Motion Factor (376): 1.000000, 1.000000
        Synaptics Resolution Detect (377):      1
        Synaptics Grab Event Device (378):      0
        Synaptics Gestures (379):       1
        Synaptics Capabilities (380):   1, 0, 0, 1, 1, 0, 0
        Synaptics Pad Resolution (381): 12, 12
        Synaptics Area (382):   0, 0, 0, 0
        Synaptics Soft Button Areas (383):      666, 0, 678, 0, 0, 0, 0, 0
        Synaptics Noise Cancellation (384):     7, 7
        Device Product ID (317):        1739, 33391
        Device Node (316):      "/dev/input/event11"
As you can see, the Synaptics drivers are now used instead of the libinput drivers before.
