-1
The problem occurs when trying to install ubuntu 22.04 LTS or 23.10.
If you run try or install without nomodeset, then in almost all cases the screen goes off and nothing happens (a couple of times I managed to get to launch, but almost immediately the system stuck dead).
I tried to run it with nomodeset. It was possible to get to the launch, but often the system stuck dead after a question about wi-fi.
It was installed once, but the same problems occurred at startup: without nomodeset, the screen is black, with nomodeset, it stuck deadly after a couple of minutes after startup.
Notebook ASUS ROG STRIX SCAR 15 (2021).
AMD Ryzen™ 9 5900HX NVIDIA® GeForce RTX™ 3070 Laptop GPU
I figured it out a bit.
The problem was not with the ubuntu versions. As I found out, when the laptop is running on battery power, everything is fine, when I connect the charging, the system freezes after a few minutes.
Also, if you run ubuntu without charging, then everything works fine. If with charging connected, then the screen is black and stuck.
So I'll deal with it.
