Alternative 01: (See alternative 02 or @Raffa's comment for shortcoming of alternative 01.)
Lets create our temporary directory, and own it as normal user so that we can write to it as normal user:
sudo mkdir /my_temp_files/
sudo chown $USER:$USER /my_temp_files/
Lets write a script to remove the temporary files at system startup. We will store the script in the following directory:
sudo mkdir -p /opt/remove_my_temp_files/bin/
Create a file named remove_my_temp_files.sh as:
sudo touch /opt/remove_my_temp_files/bin/remove_my_temp_files.sh
sudo chmod 755 /opt/remove_my_temp_files/bin/remove_my_temp_files.sh
sudo chown root:root /opt/remove_my_temp_files/bin/remove_my_temp_files.sh
Write the folling to this file:
#!/bin/bash
if [[ -d /my_temp_files ]] ; then
rm -fr /my_temp_files/*
rm -fr /my_temp_files/.*
fi
Now, create a file named remove_my_temp_files.service as:
sudo touch /etc/systemd/system/remove_my_temp_files.service
sudo chmod 644 /etc/systemd/system/remove_my_temp_files.service
sudo chown root:root /etc/systemd/system/remove_my_temp_files.service
And write the following to this file:
[Unit]
Description=Removes My Temporary Files.
[Service]
Type=oneshot
ExecStart=-/bin/bash -c '/opt/remove_my_temp_files/bin/remove_my_temp_files.sh'
[Install]
WantedBy=multi-user.target
Now, finally enable remove_my_temp_files.service as:
sudo systemctl enable remove_my_temp_files.service
Now, files and directories created within this /my_temp_files/ directory will be deleted on every system startup.
Alternative 02:
As @Raffa suggests in his comments below, my way of rm /path/to/dir/* is limited by the permitted size of command line, and using system service is bit too much for a task that can be simply accomplished by crontab as he suggests, here is the alternative answer:
Write the following code in $HOME/bin/remove_user_temp.sh :
#!/bin/bash
declare MY_TEMP_DIR="$HOME/my_temp_dir/"
if [[ -e "$MY_TEMP_DIR" ]] ; then
rm -rf "$MY_TEMP_DIR"
if [[ ! -e "$MY_TEMP_DIR" ]] ; then
mkdir "$MY_TEMP_DIR"
fi
fi
Make this script executable:
chmod +x $HOME/bin/remove_user_temp.sh
Edit the crontab with:
crontab -e
Choose the file editor of your choice, if permitted, then begin with editing the cron job. At the end of the file, add:
@reboot $HOME/bin/remove_user_temp.sh
Save your edit, and exit crontab. This will also delete the files in your temporary directory at system reboot.
Alternative 03:
Easiest alternative is to put your temporary files in /tmp/ or /dev/shm/ directory. The files stored in /tmp will get deleted next time your system boots up, while those in /dev/shm are stored in computer's memory (rather than on the disk) and will be deleted when the computer shuts down or goes to reboot.
