I'm using Ubunut 22.04, I want to install nvidia driver: sudo ./cuda_12.1.0_530.30.02_linux.run, but I get a warning first:
   warning: the compiler differs from the one used to build the kernel
     The kernel was built by: x86_64-linux-gnu-gcc-12 (Ubuntu 12.3.0-1ubuntu1~22.04) 12.3.0
     You are using:           cc (Ubuntu 11.4.0-1ubuntu1~22.04) 11.4.0
Warning: Compiler version check failed:
The major and minor number of the compiler used to compile the kernel:
x86_64-linux-gnu-gcc-12 (Ubuntu 12.3.0-1ubuntu1~22.04) 12.3.0, GNU ld (GNU Binutils for Ubuntu) 2.38
does not match the compiler used here:
I already followed this solution to change the version to 12.3, and when I check from the terminal I get gcc/g++ version 12.3.
Finally I get an error: cc: error: unrecognized command-line option '-ftrivial-auto-var-init=zero', can you please tell me how can I solve that? thanks in advance.
Bilal
  • 357
Defining the gcc version explicitly
CC="gcc-12" sudo ./cuda_12.1.0_530.30.02_linux.run
solved this issue.
zx485
  • 2,865
Bilal
  • 357
