I am trying to unzip files supplied by Google Takeout and need a command to unzip all zip files in a directory to a directory of the same name as the zip file to avoid conflicts. The zip names cannot be pre-determined so therefore neither can the resulting unzipped directories.
Eg
-zipstore
----zipname1.zip
----zipname2.zip
should result in
-zipstore
----zipname1.zip
----zipname1
----zipname2.zip
----zipname2
Where zipname1 and zipname2 are the directories containing the unzipped files.
A further consideration is how do I detect if the zip has finished downloading before extracting - these are 10Gb files !!
muru
  • 207,228
AFAIK, unzip doesn't support that natively, but it supports specifying an extraction directory name with -d.
So, for extracting single archives, you can define your own function making use of the shell's parameter expansion to strip out the extension part i.e. .zip in the filename like this:
myunzip ()
    unzip "$1" -d "${1%.zip}"
... and then use it like so:
myunzip zipname1.zip
or use a shell loop for extracting all archive files in the current working directory at once like so:
for a in *.zip; do unzip "$a" -d "${a%.zip}"; done
However, to constantly monitor a certain download directory and automatically unzip completed zip archive files downloads, you'll need to set a watch on that directory using e.g. inotifywait with its close_write event (to wait until the archive file has completely downloaded and written to disk). Which you can implement in a script like:
#!/bin/bash
inotifywait -m -q -e close_write /path/to/dir/ | while read -r path action file; do if [[ "$file" =~ .*.zip$ ]]; then unzip "$path$file" -d "${path}${file%.zip}" fi done
Raffa
  • 34,963
