-1
I encounter this problem while trying to sudo apt upgrade my system:
Preparing to unpack .../nodejs_18.17.1-deb-1nodesource1_amd64.deb ...
Unpacking nodejs (18.17.1-deb-1nodesource1) over (12.22.9~dfsg-1ubuntu3.3) ...
dpkg: error processing archive /var/cache/apt/archives/nodejs_18.17.1-deb-1nodesource1_amd64.deb (--unpack):
 trying to overwrite '/usr/share/systemtap/tapset/node.stp', which is also in package libnode72:amd64 12.22.9~dfsg-1ubun
tu3.3
How to safely solve this problem?
If this helps, I remember that I installed NodeJS from github (since apt is serving v.12 or something). I use Ubuntu 22.04.3 LTS (GNU/Linux 6.5.0-15-generic x86_64).
Thanks in advance!
karel
  • 122,292
  • 133
  • 301
  • 332
stealz
  • 97
Okay, it turns out that I have had installed nodejs back then which was in conflict with node.
nodejs -v showed v.12.22.9 and node -v was v.20.7.0.
After sudo apt remove nodejs it works fine - sudo apt upgrade succeded.
stealz
  • 97
