I needed to free up some space in bpool to add the latest patches to my Ubuntu 22.04 system running ZFS. I tried to ZFS destroy the oldest snapshot, and upon reboot, booting failed with the following:
Booting a command list
error: no such device: 9a3acf1a88182eec.
Loading Linux 6.2.0-34-generic ...
error: file '/BOOT/ubuntu_uad4uk@/vmlinuz-6.2.0-34-generic' not found
Loading initial ramdisk ...
error: you need to load the kernel first.
Press any key to continue...
How do I fix my system without destroying my data and rpool? What is the device 9a3acf1a88182eec? I am a long-time Unix (Solaris) user, but not very familiar with Ubuntu admin or grub.
I originally installed from the live disk, and it created the bpool and rpool zfs pools, and booted from an EFI partition on a nvram disk.
I have tried booting Ubuntu Live from a USB and can import, mount, and look at the bpool ZFS. All of the kernels I had are there, including all the files/directories that were visible from the bpool mounted on the /boot directory before the problem. I can also mount the EFI partition and see the grub stuff, so I think all of the files I had before are not missing.
The grub entry that gave the above message is:
setparams 'Ubuntu 22.04.3 LTS, with Linux 6.2.0-34-generic'
    recordfail
    load_video
    gfxmode ${linux_gfx_mode}
    insmod gzio
    if [ "${grub_platform}" = xen ] ; then insmod xzio; insmod lzopio; fi
    insmod part_gpt
    insmod zfs
    search --no-floppy --fs-uuid --set=root 9a3acf1a88182eec
    echo Loading Linux 6.2.0-34-generic ...
    linux "/BOOT/ubuntu_uad4uk@/vmlinuz-6.2.0-34-generic" root=ZFS="rpool/ROOT/ubuntu_ad4uk" l_iommu=on,igfx_off quiet splash ${vt_handoff}
    echo 'Loading initial ramdisk ...'
    initrd "/BOOT/ubuntu_uad4uk@/initrd.img-6.2.0-34-generic"
I have tried to follow the suggestion of @Daniel T, and update-grub gives
/# update-grub
Sourcing file `/etc/default/grub'
Sourcing file `/etc/default/grub.d/init-select.cfg'
Generating grub configuration file ...
grub-probe: error: compression algorithm inherit not supported
Memtest86+ needs a 16-bit boot, that is not available on EFI, exiting
Warning: os-prober will not be executed to detect other bootable partitions.
Systems on them will not be added to the GRUB boot configuration.
Check GRUB_DISABLE_OS_PROBER documentation entry.
Adding boot menu entry for UEFI Firmware Settings ...
done
When I run grub-install, I get:
/# grub-install --target=x86_64-efi --efi-directory=/boot/efi       --bootloader-id=ubuntu --recheck —no-floppy
Installing for x86_64-efi platform.
grub-install: error: compression algorithm inherit not supported
stumblebee
  • 4,379
