I need to resize /dev/nvme0n1p1 partition because it takes almost all memory from my SSD. And also I couldn't make dual boot for Windows as second OS, so I need help.
I've tried this commands to change read-only files to read-write, but just don't understand why it didn't make any changes.
sudo mount -o remount,rw /
sudo mount -o remount,rw /dev/nvme0n1p1
also this commands
sudo fsck.ext4 -f /dev/nvme0n1p1
sudo mount -vo remount,rw /
I couldn't provide screenshots from Gparted app yet, because I just create my account, it displays this massege while I tried unmount the partition manualy...
Could not unmount /dev/nvme0n1p1
#unmount -v '/'
unmount:/:target is busy
Thanks for any help guys
Here the output of this command sudo fdisk -l
Disk /dev/loop0: 4 KiB, 4096 bytes, 8 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop1: 55.66 MiB, 58363904 bytes, 113992 sectors
Disk /dev/loop2: 61.89 MiB, 64901120 bytes, 126760 sectors
Disk /dev/loop3: 74.11 MiB, 77713408 bytes, 151784 sectors
Disk /dev/loop4: 155.63 MiB, 163188736 bytes, 318728 sectors
Disk /dev/loop5: 262.09 MiB, 274821120 bytes, 536760 sectors
Disk /dev/loop6: 349.7 MiB, 366682112 bytes, 716176 sectors
Disk /dev/loop7: 248.76 MiB, 260841472 bytes, 509456 sectors
Disk /dev/nvme0n1: 953.87 GiB, 1024209543168 bytes, 2000409264 sectors
Disk model: Timetec MS10
Disklabel type: gpt
Disk identifier: 847731F5-0940-469A-9630-B5819D5EFCF6
Device Start End Sectors Size Type
/dev/nvme0n1p1 2048 1050623 1048576 512M EFI System
/dev/nvme0n1p2 1050624 2000408575 1999357952 953.4G Linux filesystem
Disk /dev/loop8: 496.98 MiB, 521121792 bytes, 1017816 sectors
Disk /dev/loop9: 81.26 MiB, 85209088 bytes, 166424 sectors
Disk /dev/loop10: 91.69 MiB, 96141312 bytes, 187776 sectors
Disk /dev/loop11: 45.86 MiB, 48087040 bytes, 93920 sectors
Disk /dev/loop12: 12.32 MiB, 12922880 bytes, 25240 sectors
Disk /dev/loop13: 40.43 MiB, 42393600 bytes, 82800 sectors
Disk /dev/loop14: 284 KiB, 290816 bytes, 568 sectors
Disk /dev/loop15: 452 KiB, 462848 bytes, 904 sectors
Disk /dev/loop16: 659.28 MiB, 691302400 bytes, 1350200 sectors
