It's showing me:
[ FAILED] Failed to start Process Error reports when automatic reporting is enabled
The NVIDIA GeForce GT 620 GPU installed in the system is supported through the NVIDIA 390.xx Legacy drivers. Please visit http://www.nvidia.com/object/unix.html for more information. The 535.154.05 NVIDIA driver will ignore this GPU. Continuing probe...
I can boot into TTY#s, but they keep on getting overridden by the NVRM messages.
There is a tool called ubuntu-drivers that lets you list and switch all available drivers.
$ ubuntu-drivers
Usage: ubuntu-drivers [OPTIONS] COMMAND [ARGS]...
Options: --gpgpu gpgpu drivers --free-only Only consider free packages --package-list PATH Create file with list of installed packages (in install mode) --no-oem Do not include OEM enablement packages (these enable an external archive) -h, --help Show this message and exit.
Commands: debug Print all available information and debug data about drivers. devices Show all devices which need drivers, and which packages... install Install a driver [driver[:version][,driver[:version]]] list Show all driver packages which apply to the current system. list-oem Show all OEM enablement packages which apply to this system
So as long as you can get to a prompt you can switch to another driver.
Use ubuntu-drivers --gpgpu list (or list-oem) to show the available drivers and 'install' to install the chosen one.
Rinzwind
  • 309,379
