When I boot my Ubuntu 23.10 system with autologin enabled I get the error "Oh no! Something has gone wrong. A problem has occured and the system can't recover. Please log out and try again". After I log out, put my password and log back in everything works fine but I'd like to be able to use the autologin. Here is what my system log says right after I log in.
04:10:46 seahorse: SoftHSM.cpp(527): Could not load the configuration
04:10:31 gsd-smartcard: SoftHSM.cpp(527): Could not load the configuration
04:10:29 bluetoothd: Failed to add UUID: Failed (0x03)
04:10:28 gdm-session-wor: gkr-pam: couldn't unlock the login keyring.
04:10:28 bluetoothd: Failed to remove UUID: Failed (0x03)
04:10:15 gsd-smartcard: SoftHSM.cpp(527): Could not load the configuration
04:10:15 systemd: Failed to start org.gnome.Shell@x11.service - GNOME Shell on X11.
04:10:06 gdm-session-wor: gkr-pam: couldn't unlock the login keyring.
04:10:05 systemd: Failed to start thermald.service - Thermal Daemon Service.
04:10:01 kernel: 04:10:00 kernel: ACPI Error: Aborting method _SB.PCI0.SAT0.PRT0._GTF due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
04:10:00 kernel: tpm_crb MSFT0101:00: [Firmware Bug]: ACPI region does not cover the entire command/response buffer. [mem 0xfed40000-0xfed4087f flags 0x201] vs fed40080 f80
Error
