(This is a follow up to this question)
I think I messed up the system while trying to fix some issues. I tried to update Nvidia driver (the one that shows by nvidia-smi) and also installed several different CUDA toolkit versions (I should've used .run version instead of deb). I found that when I install CUDA toolkit from Nvidia website, it also changes the driver.
I'm using Ubuntu 22.04
Now I want to clean up some nvidia drivers but I don't know how to.
How do I clean up these versions shown under Version table?
jun@hotcake:~$ apt policy nvidia-driver-470
nvidia-driver-470:
Installed: (none)
Candidate: 470.223.02-0ubuntu1
Version table:
470.223.02-0ubuntu1 600
600 https://developer.download.nvidia.com/compute/cuda/repos/ubuntu2004/x86_64 Packages
470.223.02-0ubuntu0.22.04.1 500
500 http://security.ubuntu.com/ubuntu jammy-security/restricted amd64 Packages
500 http://archive.ubuntu.com/ubuntu jammy-updates/restricted amd64 Packages
500 https://ppa.launchpadcontent.net/graphics-drivers/ppa/ubuntu jammy/main amd64 Packages
470.199.02-1pop0~1702484215~22.04~b922bc0~dev 500
500 https://ppa.launchpadcontent.net/system76-dev/stable/ubuntu jammy/main amd64 Packages
470.199.02-0ubuntu1 600
470.182.03-0ubuntu1 600
470.161.03-0ubuntu1 600
470.141.10-0ubuntu1 600
470.141.03-0ubuntu1 600
470.129.06-0ubuntu1 600
470.103.01-0ubuntu2 500
500 http://archive.ubuntu.com/ubuntu jammy/restricted amd64 Packages
470.103.01-0ubuntu1 600
470.82.01-0ubuntu1 600
470.57.02-0ubuntu1 600
470.42.01-0ubuntu1 600
Adding some other info just in case it might help.
| NVIDIA-SMI 470.223.02 Driver Version: 470.223.02 CUDA Version: 11.4 |
| GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC |
| Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. |
| | | MIG M. |
| 0 NVIDIA GeForce ... Off | 00000000:41:00.0 On | Off |
| 0% 39C P8 15W / 480W | 0MiB / 24253MiB | 0% Default |
| | | N/A |
| Processes: |
| GPU GI CI PID Type Process name GPU Memory |
| ID ID Usage |
| No running processes found |
jun@hotcake:~$ nvcc -V
nvcc: NVIDIA (R) Cuda compiler driver
Copyright (c) 2005-2022 NVIDIA Corporation
Built on Wed_Sep_21_10:33:58_PDT_2022
Cuda compilation tools, release 11.8, V11.8.89
Build cuda_11.8.r11.8/compiler.31833905_0
