The problem can be reproduced as follows:
  1. When I remove the password of an administrator account, "Log In without Password", I cannot use that account to authenticate.
  2. When I do something that requires authentication, I cannot use an admin without a password to authenticate. If I leave the password box blank without a password while choosing a non-password admin, authentication fails (in terminal or in GUI).
How to fix this problem?
Nanne
  • 8,685
The answer, you don't. You will need to set a password in order to authenticate to do anything requiring authentication.
Unfortunately after the password has been removed you cannot even change your password as you must be able to authenticate in order to change your password in the settings / user account screen.
The fix:
  1. Change your password using Terminal.
    Click the windows key or click the dash button to go to the dashboard. In the search box type term and click on the program called terminal.
  2. Type who am i and press enter to verify you are logged in as the user that you want to change.
  3. Type passwd and press enter. It will then ask you what password you want to change it to. Enter your new password and press enter. Then it will ask you to enter your password again to verify. Enter your password again and then press enter. Your password will now be set and you will now be able to authenticate again by using your new password.
Eliah Kagan
  • 119,640
j0vian
  • 41
Automatic login, "Login without Password," doesn't actually remove the password from your account--it simply fills it in for you when you log in. To authenticate (such as for gksu) you still type the same password you used to log in before.
Kerrick
  • 1,861
If you are asking how to restore the password to your account and/or add that account to the sudo user group, the answers to these other (duplicate?) questions may help.
I deleted my original user account. The new account has no password. How can I enable it?
How do I add myself back as a sudo user?
