When I click on the switch like button in Settings it doesn't turn on, even though the button looks like it is. It still says 'Bluetooth Turned Off' below. I have turned on my earbuds to see if they would be able to connect but nothing happens.
Tried sudo apt update && sudo apt upgrade but that didn't work.
uname -a returns
Linux tony-Satellite-C55-C 6.5.0-15-generic #15~
22.04.1-Ubuntu SMP PREEMPT_DYNAMIC
Fri Jan 12 18:54:30 UTC 2 x86_64 x86_64 x86_64 GNU/Linux
journalctl -r -u bluetooth -b -0 returns
Jan 29 20:47:03 tony-Satellite-C55-C bluetoothd[617]: Bluetooth management inte>
Jan 29 20:47:03 tony-Satellite-C55-C bluetoothd[617]: Starting SDP server
Jan 29 20:47:03 tony-Satellite-C55-C systemd[1]: Started Bluetooth service.
Jan 29 20:46:58 tony-Satellite-C55-C bluetoothd[617]: Bluetooth daemon 5.64
Jan 29 20:46:57 tony-Satellite-C55-C systemd[1]: Starting Bluetooth service...
rfkill returns
    ID TYPE      DEVICE                 SOFT      HARD
 0 bluetooth Toshiba Bluetooth unblocked unblocked
 1 wlan      phy0              unblocked unblocked
 2 wlan      brcmwl-0          unblocked unblocked
 3 bluetooth hci0              unblocked unblocked
lspci returns
00:00.0 Host bridge: Intel Corporation Haswell-ULT DRAM Controller (rev 0b)
00:02.0 VGA compatible controller: Intel Corporation Haswell-ULT Integrated Graphics Controller (rev 0b)
00:03.0 Audio device: Intel Corporation Haswell-ULT HD Audio Controller (rev 0b)
00:14.0 USB controller: Intel Corporation 8 Series USB xHCI HC (rev 04)
00:16.0 Communication controller: Intel Corporation 8 Series HECI #0 (rev 04)
00:1b.0 Audio device: Intel Corporation 8 Series HD Audio Controller (rev 04)
00:1c.0 PCI bridge: Intel Corporation 8 Series PCI Express Root Port 1 (rev e4)
00:1c.2 PCI bridge: Intel Corporation 8 Series PCI Express Root Port 3 (rev e4)
00:1c.3 PCI bridge: Intel Corporation 8 Series PCI Express Root Port 4 (rev e4)
00:1c.5 PCI bridge: Intel Corporation 8 Se00:00.0 Host bridge: Intel Corporation Haswell-ULT DRAM Controller (rev 0b)
00:1c.5 PCI bridge: Intel Corporation 8 Series PCI Express Root Port 6 (rev e4)
00:1d.0 USB controller: Intel Corporation 8 Series USB EHCI #1 (rev 04)
00:1f.0 ISA bridge: Intel Corporation 8 Series LPC Controller (rev 04)
00:1f.2 SATA controller: Intel Corporation 8 Series SATA Controller 1 [AHCI mode] (rev 04)
00:1f.3 SMBus: Intel Corporation 8 Series SMBus Controller (rev 04)
07:00.0 Network controller: Broadcom Inc. and subsidiaries BCM43142 802.11b/g/n (rev 01)
08:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL810xE PCI Express Fast Ethernet controller (rev 07)
09:00.0 Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. RTS5229 PCI Express Card Reader (rev 01)
I tried running sudo dmesg and I do get some errors:
[   24.237131] Bluetooth: hci0: BCM: firmware Patch file not found, tried:
[   24.237166] Bluetooth: hci0: BCM: 'brcm/BCM43142A0-0930-0225.hcd'
[   24.237188] Bluetooth: hci0: BCM: 'brcm/BCM-0930-0225.hcd'
[   26.252958] Bluetooth: hci0: command 0x1003 tx timeout
[   26.252959] Bluetooth: hci0: Opcode 0x1003 failed: -110
So it seems like I'm missing some firmware. I'm not sure where I'm supposed to get it from.
When I ran bluetoothctl then try power on & scan on they both came back with "No default controller available"
Biggs
