-1
With apt-get update I got the error message:
Reading package lists... done
N: Skipping acquire of configured file "main/binary-i386/Packages"
as repository "https://repo.ckvsoft.at/ckvsoft jammy-ckvsoft-stable InRelease" doesn't support architecture 'i386'.
I have been looking in the apt directory but there is no File with "main/binary-i386/Packages". This is a newly build system that is fully 64-bit.
I found that Google Chrome could be responsible, but there is no repository that points to Google.
karel
  • 122,292
  • 133
  • 301
  • 332
Stajl
  • 27
You probably want to enable i386 to get rid of the error, instead of deleting i386. Can't install i386 package(s) says sudo dpkg --add-architecture i386, assuming your 64-bit system is Intel/AMD not ARM. It is likely that your "ckvsoft" vendor wants to continue shipping 32-bit software, and you want to install it.
If you really want to remove i386 together with this "ckvsoft" thing:
cd /etc/apt/sources.list.d # This is the one of many apt directories you seek
grep ckvsoft -r .
sudo rm ./name-of-the-file.list
# Depending on how you installed it,
# there might be cleaner ways like
# `apt remove name_of_package_for_the_list` or
# https://askubuntu.com/q/307/1004020
# that remove the gpg key as well
# but they require more assumptions
sudo rm -rf /var/lib/apt/lists/* sudo apt update
Daniel T
  • 5,339
