Having a trouble trying to install logwatch on Ubuntu 22.04 LTS. Here is the output when trying to install:
# apt install logwatch
Reading package lists... Done
Building dependency tree... Done
logwatch is already the newest version (7.5.6-1ubuntu1).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
2 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n]
Setting up postfix (3.6.4-1ubuntu1.1) ...
postconf: warning: open /etc/postfix/master.cf: No such file or directory
usermod: user 'postfix' does not exist in /etc/passwd
dpkg: error processing package postfix (--configure):
installed postfix package post-installation script subprocess returned error exit status 6
dpkg: dependency problems prevent configuration of logwatch:
logwatch depends on default-mta | mail-transport-agent; however:
Package default-mta is not installed.
Package postfix which provides default-mta is not configured yet.
Package mail-transport-agent is not installed.
Package postfix which provides mail-transport-agent is not configured yet.
dpkg: error processing package logwatch (--configure):
dependency problems - leaving unconfigured
No apport report written because the error message indicates its a followup error from a previous failure.
postfix
logwatch
needrestart is being skipped since dpkg has failed
I tried install the dependencies for and I am getting error for postfix as well.
# apt install postfix
postfix is already the newest version (3.6.4-1ubuntu1.1).
postfix set to manually installed.
postfix
logwatch
Even when I try to install default-mta, I get the same error. Googling the web and trying many different suggestions have not worked either. As a last resort I decided to open create this question here.
# apt install default-mta
Note, selecting 'postfix' instead of 'default-mta'
postfix
logwatch
EDIT1: I tried as suggested below the commands:
# dpkg --configure -a
logwatch
# apt autoremove
postfix
logwatch
# apt install -f
postfix
logwatch
EDIT2: Here is the output of dpkg-reconfigure -a command:
# dpkg-reconfigure -a
Unknown option: a
Usage: dpkg-reconfigure [options] packages
-u, --unseen-only Show only not yet seen questions.
--default-priority Use default priority instead of low.
--force Force reconfiguration of broken packages.
--no-reload Do not reload templates. (Use with caution.)
-f, --frontend Specify debconf frontend to use.
-p, --priority Specify minimum priority question to show.
--terse Enable terse mode.
