I am dual-booting Windows 7 and Ubuntu 12.04. I reduced my Windows 7 partition and increased my Ubuntu partition using gparted from a 12.04 live CD. Everything was fine for about a week. Then the other day I booted and was met with "grub rescue." I purged and re-installed both grub and then grub2 as per the many tutorials on line, but all efforts have met with the same results: It seems that os-prober sees my 2 Windows 7 (actual and restore) partitions, as well as the Ubuntu 12.04 LTS partition; but when I run any variant of update-grub or update-grub2, it only detects the 2 Windows 7 partitions. As a result I cannot boot into Ubuntu (which is where 99% of my work is). Here is the output of bootinfoscript:
    Boot Info Script 0.61      [1 April 2012]
============================= Boot Info Summary: ===============================
 => Grub2 (v1.99) is installed in the MBR of /dev/sda and looks at sector 1 of
    the same hard drive for core.img. core.img is at this location and looks
    for (,msdos5)/boot/grub on this drive.
sda1: __________________________________________________________________________
    File system:       ntfs
    Boot sector type:  Windows Vista/7: NTFS
    Boot sector info:  No errors found in the Boot Parameter Block.
    Operating System:
    Boot files:        /bootmgr /Boot/BCD
sda2: __________________________________________________________________________
    File system:       ntfs
    Operating System:  Windows 7
    Boot files:        /bootmgr /Boot/BCD /Windows/System32/winload.exe
sda3: __________________________________________________________________________
    File system:       ntfs
    Operating System:
    Boot files:
sda4: __________________________________________________________________________
    File system:       Extended Partition
    Boot sector type:  -
    Boot sector info:
sda5: __________________________________________________________________________
    File system:       ext4
    Boot sector type:  Grub2 (v1.99)
    Boot sector info:  Grub2 (v1.99) is installed in the boot sector of sda5
                       and looks at sector 525161552 of the same hard drive
    Operating System:  Ubuntu 12.04 LTS
    Boot files:        /boot/grub/grub.cfg /etc/fstab /boot/grub/core.img
sda6: __________________________________________________________________________
    File system:
    Boot sector type:  -
    Boot sector info:
    Mounting failed:   mount: unknown filesystem type ''
============================ Drive/Partition Info: =============================
Drive: sda _____________________________________________________________________
Disk /dev/sda: 320.1 GB, 320072933376 bytes
255 heads, 63 sectors/track, 38913 cylinders, total 625142448 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
Partition  Boot  Start Sector    End Sector  # of Sectors  Id System
/dev/sda1               2,048       206,847       204,800   7 NTFS / exFAT / HPFS
/dev/sda2             206,848   504,360,959   504,154,112   7 NTFS / exFAT / HPFS
/dev/sda3         591,218,688   625,137,663    33,918,976   7 NTFS / exFAT / HPFS
/dev/sda4         504,360,960   591,218,687    86,857,728   5 Extended
/dev/sda5    *    504,363,008   583,360,511    78,997,504  83 Linux
/dev/sda6         583,362,560   591,218,687     7,856,128  82 Linux swap / Solaris
"blkid" output: ________________________________________________________________
Device           UUID                                   TYPE       LABEL
/dev/loop0                                              squashfs
/dev/sda1        DA669D8C669D69D1                       ntfs       System Reserved
/dev/sda2        BAAAA703AAA6BAF1                       ntfs
/dev/sda3        8E22D1E022D1CCF9                       ntfs       OS Recovery
/dev/sda5        c35e7a0a-408c-4586-8a18-b3faa368ef3f   ext4
/dev/sr0                                                iso9660    Ubuntu 12.04 LTS amd64
================================ Mount points: =================================
Device           Mount_Point              Type       Options
/dev/loop0       /rofs                    squashfs   (ro,noatime)
/dev             /mnt/dev                 none       (rw,bind)
/dev/pts         /mnt/dev/pts             none       (rw,bind)
/dev/sda2        /media/BAAAA703AAA6BAF1  fuseblk    (rw,nosuid,nodev,allow_other,default_permissions,blksize=4096)
/dev/sda5        /media/c35e7a0a-408c-4586-8a18-b3faa368ef3f ext4       (rw,nosuid,nodev,uhelper=udisks)
/dev/sda5        /mnt                     ext4       (rw)
/dev/sr0         /cdrom                   iso9660    (ro,noatime)
=========================== sda5/boot/grub/grub.cfg: ===========================
# DO NOT EDIT THIS FILE
# It is automatically generated by grub-mkconfig using templates
# from /etc/grub.d and settings from /etc/default/grub
### BEGIN /etc/grub.d/00_header ###
if [ -s $prefix/grubenv ]; then
  set have_grubenv=true
  load_env
fi
set default="0"
if [ "${prev_saved_entry}" ]; then
  set saved_entry="${prev_saved_entry}"
  save_env saved_entry
  set prev_saved_entry=
  save_env prev_saved_entry
  set boot_once=true
fi
function savedefault {
  if [ -z "${boot_once}" ]; then
    saved_entry="${chosen}"
  fi
function recordfail {
  set recordfail=1
  if [ -n "${have_grubenv}" ]; then if [ -z "${boot_once}" ]; then save_env recordfail; fi; fi
function load_video {
  insmod vbe
  insmod vga
  insmod video_bochs
  insmod video_cirrus
insmod part_msdos
insmod ext2
set root='(hd0,msdos5)'
search --no-floppy --fs-uuid --set=root c35e7a0a-408c-4586-8a18-b3faa368ef3f
if loadfont /usr/share/grub/unicode.pf2 ; then
  set gfxmode=auto
  load_video
  insmod gfxterm
  insmod part_msdos
  insmod ext2
  set locale_dir=($root)/boot/grub/locale
  set lang=en_US
  insmod gettext
fi
terminal_output gfxterm
if [ "${recordfail}" = 1 ]; then
  set timeout=-1
else
  set timeout=10
fi
### END /etc/grub.d/00_header ###
### BEGIN /etc/grub.d/05_debian_theme ###
set menu_color_normal=white/black
set menu_color_highlight=black/light-gray
if background_color 44,0,30; then
  clear
fi
### END /etc/grub.d/05_debian_theme ###
### BEGIN /etc/grub.d/10_linux ###
function gfxmode {
    set gfxpayload="${1}"
    if [ "${1}" = "keep" ]; then
        set vt_handoff=vt.handoff=7
    else
        set vt_handoff=
    fi
if [ "${recordfail}" != 1 ]; then
  if [ -e ${prefix}/gfxblacklist.txt ]; then
    if hwmatch ${prefix}/gfxblacklist.txt 3; then
      if [ ${match} = 0 ]; then
        set linux_gfx_mode=keep
      else
        set linux_gfx_mode=text
      fi
    else
    fi
  else
  fi
else
fi
export linux_gfx_mode
if [ "${linux_gfx_mode}" != "text" ]; then load_video; fi
### END /etc/grub.d/10_linux ###
### BEGIN /etc/grub.d/20_linux_xen ###
### END /etc/grub.d/20_linux_xen ###
### BEGIN /etc/grub.d/30_os-prober ###
menuentry "Windows 7 (loader) (on /dev/sda1)" --class windows --class os {
    insmod part_msdos
    insmod ntfs
    set root='(hd0,msdos1)'
    search --no-floppy --fs-uuid --set=root DA669D8C669D69D1
    chainloader +1
### END /etc/grub.d/30_os-prober ###
### BEGIN /etc/grub.d/40_custom ###
# This file provides an easy way to add custom menu entries.  Simply type the
# menu entries you want to add after this comment.  Be careful not to change
# the 'exec tail' line above.
### END /etc/grub.d/40_custom ###
### BEGIN /etc/grub.d/41_custom ###
if [ -f  $prefix/custom.cfg ]; then
  source $prefix/custom.cfg;
fi
### END /etc/grub.d/41_custom ###
=============================== sda5/etc/fstab: ================================
# /etc/fstab: static file system information.
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
# <file system> <mount point>   <type>  <options>       <dump>  <pass>
proc            /proc           proc    nodev,noexec,nosuid 0       0
# / was on /dev/sda5 during installation
UUID=c35e7a0a-408c-4586-8a18-b3faa368ef3f /               ext4    errors=remount-ro 0       1
# swap was on /dev/sda6 during installation
#UUID=a4d335d5-6a81-4af8-a1c7-3beeee8699a1 none            swap    sw              0       0
/dev/mapper/cryptswap1 none swap sw 0 0
=================== sda5: Location of files loaded by Grub: ====================
           GiB - GB             File                                 Fragment(s)
               =                boot/grub/core.img                             1
               =                boot/grub/grub.cfg                             1
========= Devices which don't seem to have a corresponding hard drive: =========
sdb
=============================== StdErr Messages: ===============================
xz: (stdin): Compressed data is corrupt
awk: cmd. line:36: Math support is not compiled in
And of sudo os-prober from 12.04 LiveCD:
/dev/sda1:Windows 7 (loader):Windows:chain
/dev/sda2:Windows 7 (loader):Windows1:chain
/dev/sda5:Ubuntu 12.04 LTS (12.04):Ubuntu:linux
I have read pretty much every guide, tutorial and question that exists out there for updating any version of grub, but nothing has worked. But what is most confusing is that os-prober sees the installation; I would very much appreciate any assistance in this matter.
msolters
  • 353
Have you tried adding a "custom" menuentry to boot Ubuntu by editing grub.cfg?
I decided I might as well suggest this since even if it does not work perhaps it will result in a more useful error message.
  1. Boot your system using your 12.04 LiveCD.
  2. Mount the sda5 partition Ubuntu is installed on. In this example I will assume sda5 was mounted at /mnt using, for example, sudo mount -t ext4 /dev/sda5 /mnt.
  3. Determine which kernel(s) you have installed by listing the contents of the /mnt/boot directory. You will need this information to complete step (5) below.
    Note: The command below is one way you could do this.
    ls /mnt/boot/{initrd*,vmlinuz*}
  4. Use sudo to edit the file /mnt/boot/grub/grub.cfg (i.e. the grub.cfg file on your sda5 Ubuntu partition).
  5. Find the the lines below in the file. They should be ~10 lines before the end of the file.
    Replace the above with the GRUB commands for the menuentry below.
    Important: In the example below you must replace ?.?.?-?? in the linux and initrd lines with the version number (from step (3)) of the kernel you wish to boot.
    menuentry 'Ubuntu on sda5' --class ubuntu --class gnu-linux --class gnu --class os {
      recordfail
      insmod gzio
      insmod part_msdos
      insmod ext2
      linux /boot/vmlinuz-?.?.?-??-generic root=UUID=c35e7a0a-408c-4586-8a18-b3faa368ef3f ro quiet splash
      initrd    /boot/initrd.img-?.?.?-??-generic
  6. Reboot and see if this custom entry allows you to boot Ubuntu from /dev/sda5.
If the suggestion above worked, then I would suggest trying the following.
  • Use sudo to edit the file /etc/grub.d/40_cutom and append the menuentry commands from step (5) to the end of the file. This way the menu entry will not be lost if you run update-grub.
    Warning: Do not delete the two lines below! They need to be at the beginning of the file 40_custom for update-grub to work properly.
    #!/bin/sh
    exec tail -n +3 $0
  • Try reinstalling GRUB yet one more time using the command below. (Why not?)
    sudo grub-install --recheck /dev/sda
Update responding to comment that kernel files are missing from /boot
I've never run into a situation where the kernel files were missing from /boot. My first concern would be that if your kernel files are missing, then something else could be seriously wrong with the Ubuntu installed on sda5.
I suggest that you update your question and its title to reflect that there are no kernel files in /boot. Doing this increases your chances of getting a better answer from someone else.
I searched AskUnbuntu for a similar question, but all I found was the one linked below.
How to restore a system after accidentally removing all kernels?
The best answer to that question was to chroot and then try re-installing the kernel which you say you've already tried. The only change I could suggest is you try again using these commands. (Note: sudo was not used below because if you chroot you already are root.)
apt-get update
apt-get --reinstall install linux-generic linux-image-generic linux-headers-generic
  • Note: If the above appears to work it is probably safest to also run
The manpage for update-initramfs may also help provide some context about what happens when a kernel is "installed".
In hindsight I should have realized something was wrong from reading your BootInfo summary. It ends with the excerpt below.
sdb
But instead of the errors above I should have expected to see something like the excerpt below from a BootInfo summary I created as an example.
  23.440826416 = 25.169395712   boot/grub/core.img                             1
  23.440864563 = 25.169436672   boot/grub/grub.cfg                             1
  18.791522980 = 20.177244160   boot/initrd.img-3.2.0-23-generic               1
  25.439197540 = 27.315130368   boot/vmlinuz-3.2.0-23-generic                  1
  18.791522980 = 20.177244160   initrd.img                                     1
  25.439197540 = 27.315130368   vmlinuz                                        1
ADDITIONAL INFORMATION :
=================== log of boot-repair 2012-06-13__16h58 ===================
boot-repair version : 3.18-0ppa25~precise
boot-sav version : 3.19-0ppa14~precise
glade2script version : 0.3.2.1-0ppa7~precise
boot-repair is executed in live-session (Ubuntu 12.04 LTS , precise , Ubuntu , x86_64)
=================== OSPROBER:
... et cetera ....
Run Boot-Repair's "Recommended repair". This will reinstall GRUB and reinstall a kernel if needed. If any problem indicate the URL that will appear.
LovinBuntu
  • 3,785
